Tires/lift help
Discussion in 'Wheels & Tires' started by CWill, May 31, 2023.
  1. May 31, 2023 at 7:25 AM
    CWill
    CWill [OP] Member
    2019 TRD Sport 4X4
    I know there’s 100 threads on subjects like this, but I figured I’d ask my own question and get advice from people with much more knowledge than me.
    Any advice/help you give me is definitely appreciated.
    I have a 2019 Tacoma TRD Sport 4WD. I’m wanting to upgrade to 285/70/17 KO2’s. Local shop said a 3/1 Readylift would be all that’s necessary to accommodate that. Does that seem accurate? I do some overlanding, but nothing too extreme. Did all of the Colorado trails around Ouray last year, and that’s about as extreme as I’ll go off-road.
  2. May 31, 2023 at 7:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    Lift doesn't really create tire clearance where needed. The fitment of the wheels (offset/backspace) is much more important.
    Redi lift is just a spacer lift IIRC. Some think it's just fine, others prefer an actual suspension upgrade.
    If you traveled successfully last year on OE bits/tires, you could just upgrade the tire size slightly, the quality greatly, and be quite successful in your travels on your OE wheels.
    Also a 255 80 17 (full 33) on OE wheels fit with no lift/rub/cut.
    Consider that a suspension lift doesn't gain ground clearance at the low point of the truck, the axle lines.
    dangeroso and CWill[OP] like this.
  3. May 31, 2023 at 1:53 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    285s look awesome on our trucks, stock sport wheels don’t have enough offset, a 285 will rub on the upper control arm with sport wheels.
    You need a 7.5 or 8 inch wheel with around 0 offset or -10.
    You’ll need a good wheel alignment to run them on the street, but if you off-road then you’ll want a cmc and some minimal trimming. A cmc is like an hour at an off-road shop.
    CWill[QUOTED][OP] likes this.
  4. May 31, 2023 at 5:10 PM
    CWill
    CWill [OP] Member
    2019 TRD Sport 4X4
    Thank you for your responses. The wheels I currently have are the blackTRD Pro wheels (not sure on offset or wheel width) and I have KO2 265/70/17’s on right now. The wheel and tire I’m wanting to go to is a Method bronze wheel with the 285’s.
  5. May 31, 2023 at 11:20 PM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    The pros will work but methods are nice, like the 701
  6. Jun 1, 2023 at 7:59 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    @CWill we can help with the wheel and tire package if you would like. Method is a solid choice for aftermarket wheel and will increase your width over what you have now. Is there a Discount Tire location near you?
  7. Jun 1, 2023 at 8:10 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    You didn’t ask this, but E rated KO2s ride unbelievably rough. There’s not much flex in the sidewall at all. I had them for 2 days and hated them. Some here love them, but I had the complete opposite experience.
  8. Jun 2, 2023 at 3:51 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    You probably end up a bit nose high with a 3/1 lift. Very few of these trucks have a full 2” of rake.
