Tires making skippiong noises with RR lockers
Discussion in '1st Gen. Tacomas (1995-2004)' started by gacandido2010, Mar 18, 2012.
  1. Mar 18, 2012 at 4:02 PM
    gacandido2010
    gacandido2010 [OP] Well-Known Member
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    Bilstein 5100s, Eibach Coils, All Pro Baja Leaf Pack, Fox 2.5x16", All Pro 1.5 spacers, Deckplate Mod, K&N Filter, Magna-Flow Exhaust System, Cobra Ultra Cb with 3" Firestick, 2 Hella 500 HIDs, custom mesh grill, blacked out lettering, Limo Tint, Fog Light Mod
    went camping and wheeling up in cleghorn this weekend and noticed when i was turning with my RR lockers on it would sound like my tires were skipping?
    any explantations? im guessing its normal :cool:
  2. Mar 18, 2012 at 4:06 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    i would say probably around 20mph, but i really only noticed it when i was turning really slow
  3. Mar 18, 2012 at 4:09 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    why is that? ive heard it doesnt matter
  4. Mar 18, 2012 at 4:13 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    thanks man, good to kno its normal haha
  5. Mar 18, 2012 at 4:23 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    oh ok i feel you on that one
  6. Mar 18, 2012 at 4:57 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea watch the speed. Think about it, if you turn, the outside tire has to travel a farther distance then the inside. Thats why open diffs are so common and now limited slip, to allow the wheel to travel a different distance without damaging your diff.
    When you lock it, the wheels skip because the out side wheel want to travel farther then the inside wheel of the turn, but can't due to the inside wheel limited how much the outside wheel does turn.
    Thats why Toyota only recommend you have the locker on when needed and under 5mph. Yes you can push the speed, but really, unless you need it..keep it off. No point in having it on if your just driving a dirt road and you put more stress on your drive line.
  7. Mar 18, 2012 at 5:10 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    +1
  8. Mar 18, 2012 at 5:18 PM
    tb99trd
    tb99trd Well-Known Member
    Tom
    Petaluma CA
    99 TRD 4x4
    Bilstein 5100s (@ 2.5), Toytec 2" AAL, gray wire mod
    OP, what did you think lockers did?
  9. Mar 18, 2012 at 5:34 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    From what I understood, it says to go 5 mph or slower while engaging diff. Lock, not for the whole time you're driving. I'd assume the only thing wearing or being damaged are your tires. More specifically the one on the inside of the turn.
    How exactly does the e-locker fuse the axle together?
  10. Mar 18, 2012 at 5:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes tires do take more wear if you leave it on. As do other components because the power you send through the drive line has no place to escape. Like on an open diff if you get stuck, one wheel will spin while the other does nothing because the power goes to the easiest wheel to be released. Im at work on phone now but ill post a youtube link that will help you understand lockers better.
  11. Mar 18, 2012 at 7:17 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    You gotta remember that the term "locked" is key here, the wheels are locked into "zero" outside wheel spin to compensate for the added distance the outside wheel has to make up for, in a turn this chatter,tire chirpping is normal, whatever the speed...;)
    or it wouldn't be "locked"...
  12. Mar 18, 2012 at 9:23 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :smack:
    :D haha
