Tires, MPG & Fuel Operating Costs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaDad17, Mar 13, 2022.
  1. Mar 14, 2022 at 11:26 AM
    #41
    coma toy
    coma toy Off Road Taco
    Ehhhh, it's a truck, what did you expect? Big tires, little tires, it's still a gas gussler!
  2. Mar 14, 2022 at 11:42 AM
    #42
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    The shaitty ethanol fuel absorbs water.. if that's what you mean by "keeps it out of fuel system".
  3. Mar 14, 2022 at 11:46 AM
    #43
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  4. Mar 14, 2022 at 11:54 AM
    #44
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Exactly my point, E10 effectively dries your fuel system by allowing the ethanol to absorb any water in the system and then pass it harmlessly through the engine. Is that an issue for you?
  5. Mar 14, 2022 at 12:15 PM
    #45
    Gen3TacomaOBX
    S
    Yes, vapor lock is an issue I've experienced in other vehicles (not the Tacoma) and I don't like the fact that pure gas is not available near metro areas due to population density.
  6. Mar 14, 2022 at 12:16 PM
    #46
    Horseshoez
    Dale
    Maryland
    Yeah, I experienced vapor lock in my 1966 Plymouth Valiant; anything more recent?
  7. Mar 14, 2022 at 12:17 PM
    #47
    Gen3TacomaOBX
    S
    Yes. The temps don't have to be overly hot especially if the fuel lines have 90 degree bends.
  8. Mar 14, 2022 at 12:31 PM
    #48
    Horseshoez
    Dale
    Maryland
    I guess my point is, have you ever experienced vapor lock in a relatively modern car, regardless of OAT?
  9. Mar 14, 2022 at 12:31 PM
    #49
    Otterstuff
    Otterstuff Well-Known Member
    2022 White SR5 Access Cab 4WD V-6
    Tube steps, Vision Turbine wheels, bug deflector, seat covers, and tonneau cover
    Just because it is a truck is no reason gas mileage has to be bad. I got over 25 mpg in my 1985 Toyota 2wd manual. EPA est. for 2022 SR5 says 18 city 22 hwy. EPA ratings for Toyota have usually been lower than actual throughout the years.
  10. Mar 14, 2022 at 12:43 PM
    #50
    dan33410
    dan33410 Well-Known Member
    2020 Quicksand TRD Off Road
    I don't run TPMS in my winter set. The light will come on after a specific amount of time/distance, can't recall which. I think it is after like 30 mins? I live in a smaller community with everything within a 10 min or so drive. I won't see the light all winter unless I need to head onto the highway - aka not annoying at all. I also store my summer tires with the sensors on a tire rack on the wall next to my truck in the garage, so it's possible the truck still detects the sensors when it is started? Not sure on that though.
    willie2 and Otterstuff[QUOTED] like this.
  11. Mar 14, 2022 at 12:49 PM
    #51
    scottdogster
    scottdogster Well-Known Member
    Folsom, CA
    2019 Tacoma TRD Pro
    @DanoTay - haha… I am making the exact same switch
    Otterstuff likes this.
  12. Mar 14, 2022 at 2:06 PM
    #52
    DanoTay
    DanoTay Well-Known Member
    Victoria, B.C.
    2019 Tacoma OR AC MT
    Not only is switching from prem gas to regular going to compensate in my monthly budget for the gas price increase, my Tacoma will soon accommodate the inflation of monthly overall budgets that everyone is currently experiencing, as my Tacoma loan will be paid off in June 2022, leaving extra $ in my pocket. Well, inflation will see to $ not being mine for long.
  13. Mar 14, 2022 at 7:45 PM
    #53
    Gen3TacomaOBX
    S
    Yes.
    I see you have a single piston aircraft as your avatar. The vast majority of pilots would NEVER consider running ethanol gas (even IF they could get STC'd for it) because of the risks of vapor lock (except maybe the little rotax engines popular in Europe.) Drifting over to the side of the road isn't an option and not being able to restart a power plant can mean gliding to the crash site.
    You like ethanol gas? cool. I like the gas with more energy and less water absorbing corn in it. :thumbsup:
    Vmax540 likes this.
  14. Mar 15, 2022 at 1:54 AM
    #54
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    There's nothing better than the proper style of tire for the conditions in which you are driving and safer. Initial cost of another set of tires and rims is offset by the how long they last.
  15. Mar 15, 2022 at 3:17 AM
    #55
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    That isn’t the ethanol, that is the much higher fuel pressure and better insulated fuel system.
    Horseshoez[QUOTED] likes this.
  16. Mar 15, 2022 at 4:21 AM
    #56
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    Sure, but I personally don't like the idea of of driving on 20 year old set of tires at highway speeds. I suppose if they are stored well you could probably get 7-10 years out of them before the rubber becomes brittle.
  17. Mar 15, 2022 at 5:03 AM
    #57
    Horseshoez
    Dale
    Maryland
    And I would never run any fuel with ethanol in any aircraft with an engine designed based upon 1940s technology. The question I asked you was, "Have you ever experienced vapor lock in a relatively modern car, regardless of OAT?" I'll take your non-answers as an answer of "No". Long story short, trying to avoid using E10 in your car is a worthless exercise.
  18. Mar 15, 2022 at 5:06 AM
    #58
    Horseshoez
    Dale
    Maryland
    Exactly, which is why running E10 in a modern car is an absolute non-issue.
    18CHUÑO likes this.
  19. Mar 15, 2022 at 7:17 AM
    #59
    Gen3TacomaOBX
    S
    Do you work for the corn lobby by chance? Like I said.. enjoy your diluted fuel. I'll enjoy mine.
  20. Mar 15, 2022 at 7:41 AM
    #60
    Horseshoez
    Dale
    Maryland
    Really? No, up until my mid-60s I worked in the automotive industry, specifically as a forensic engineer for Chrysler, then Daimler-Benz, and then for Volvo. You don't have to believe there are significant benefits to E10 over 100% gasoline, but that does not in any way negate the benefits.
    And for what it's worth, while I am a fan of E10, I am definitely not a fan of increasing the ethanol content of fuels beyond that point except for specific racing applications.
