Tires on stock wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aaron2003, Oct 18, 2022.
  1. Oct 18, 2022 at 6:11 PM
    Aaron2003
    Aaron2003 [OP] New Member
    Aaron
    2002 Tacoma
    3 inch old man emu , 882 coil springs AAL dakar with 285/75/16
    does anyone have any good recommendations for some good looking tires on stock wheels?
  2. Oct 18, 2022 at 6:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    What are "good looking tires"
  3. Oct 18, 2022 at 6:13 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  4. Oct 18, 2022 at 7:17 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Well, considering you have a lift from the OME setup and you're running what I'm guessing is the original wheel which came with your 02, then my suggestion is to look into any of the following (from high to lower priced)-
    https://www.discounttire.com/buy-tires/toyo-tire-open-country-m-t/
    https://www.discounttire.com/buy-tires/cooper-discoverer-st-maxx/
    https://www.discounttire.com/buy-tires/falken-wildpeak-m-t01/p/
    https://www.discounttire.com/buy-tires/yokohama-geolandar-m-t-g003/
    https://www.discounttire.com/buy-tires/kumho-road-venture-a-t-51/
    Finally, there is the timeless, everyone seems to suggest them, hard riding and noisy BFG
    https://www.discounttire.com/buy-tires/bfgoodrich-all-terrain-t-a-ko2/
    Not happy with your current tires?
  5. Oct 19, 2022 at 11:36 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Hankook Dynapro, I'm on my second set from Discount Tire and really like them.
  6. Oct 20, 2022 at 10:14 AM
    Badknees
    Badknees Well-Known Member
    Kenny
    Anderson, SC
    1998 Tacoma Extended Cab SR-5 4X4
    King Front Coil-overs, Bilstein Rear Shocks, Add-a-leaf Rear Leaf Springs, 16" Toyota Wheels, KO2 Tires, Alpine 2-Din Head Unit, Alpine Amp, JBL GTO Speakers, Undercover Hard Bed Cover, Back-up Camera
    They may not be the best performers, but I think BFG KO2s always look the best. 1st pic KO2 on TRD Pro 17" gray wheels. 2nd pic KO2 on 16" 4Runner wheels. 3rd pic KO2 on 15" Tacoma wheels '98 Taco w TRD Pro Wheels.jpg 98 Taco Rear Bumper 4.jpg :
    straightawaykid likes this.
  7. Oct 20, 2022 at 11:09 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I never understood the fascination with the KO2's. Is it really all about the looks? It can't be about their performance from what I've seen. :stirthepot:
    Badknees, Kwikvette and Area51Runner like this.
  8. Oct 20, 2022 at 3:33 PM
    Badknees
    Kenny
    Anderson, SC
    Overall they’ve work fine for my use and needs. I also run Toyos, Coopers, and Michelins. I think each application differs and one size doesn’t fit all. Best.
    Digiratus[QUOTED] likes this.
