Tires ? on stock wheels
Discussion in 'Wheels & Tires' started by 23mrkim, Feb 24, 2024.
  1. Feb 24, 2024 at 3:57 PM
    23mrkim
    23mrkim [OP] New Member
    23 Tacoma TRD Off Road
    2" lift front / Air Lift rear
    Hi there. I installed a 2" lift in the front and air lift bags on the rear of my 2023 Tacoma TRD off road.
    Wasn't planning on getting new tires right away, but picked up a lag bolt in the side wall.
    I would like to stick with the 16" stock wheels but would like a taller tire.
    I'm worried about the clearance on the upper a arm.
    Will a 265 75 16 LT tire work.
    I've used wheel spacers in the past. I don't really want to go to different wheels, just taller tires.
    Thanks in advance
  2. Feb 24, 2024 at 4:01 PM
    SmartyMcFly
    SmartyMcFly 88 MPH
    2023 TRD Off Road 4x4 Ice Cap
  3. Feb 24, 2024 at 4:15 PM
    23mrkim
    Thank you for the info.
  4. Feb 24, 2024 at 4:19 PM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    You could even get by with SL or XL tires if you don't do a ton of offroading
  5. Feb 24, 2024 at 4:28 PM
    23mrkim
    Thank you for the reply.
    I have a 23 Jeep Rubicon also.
    Do a lot of off reading in both, but not hard core stuff.
    Mostly trail riding, exploring.
    What are SL and XL?
    Squirt likes this.
  6. Feb 24, 2024 at 4:37 PM
    Squirt
    Ben
    Standard Load and Extra Load. Generally they're a little lighter so they may not affect MPGs as much and in some cases ride better. Not as tough as an LT but if you don't always need the toughest tire non LT tires may work for your needs. Might even open up a few more choices of tires.
    Plus they are usually a little cheaper than the LTs!
  7. Feb 24, 2024 at 4:42 PM
    23mrkim
    I've always have GoodYear DuraTrac on my other 4x4's.
    I think if they will fit I will go with the LT265 75 16.
    Thank you.
    Squirt likes this.
  8. Feb 24, 2024 at 4:43 PM
    Squirt
    Ben
    :fistbump:
  9. Feb 24, 2024 at 4:43 PM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    I’d give the Falken Wildpeak AT4w’s a try. I’ve got the older 3w in a pizza cutter size (235/85/16) and they’ve been great.
