tires pointed inward?
Discussion in 'Wheels & Tires' started by tacosupreme54, Aug 5, 2010.
  1. Aug 5, 2010 at 4:27 PM
    tacosupreme54
    tacosupreme54 [OP] Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    i just recently noticed that my front tires look like they are angled inwards at the bottom. you can notice it more the farther away you are. you can't really tell as much from the pictures as you can in person. it's nothing really noticeable or significant. i was just wondering if there is something wrong? if this is typical? if it's a big deal? why is it doing this and what to do about it? or am i just over analyzing my truck?
  2. Aug 5, 2010 at 4:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you are lifted, without running aftermarket UCA's, they probably had to push the camber out a bit to get it to align close.
  3. Aug 5, 2010 at 4:29 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2...you need after market UCAs to get your alignment correct...check out Light Racing or Total Chaos
  4. Aug 5, 2010 at 4:29 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    dangs. that looks in quite a bit.
  5. Aug 5, 2010 at 4:33 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    ok, i was wondering if my tire and wheel guy had left something off or done something wrong there. but i still have stock ucas and they are pretty close to my tires, but is it alright riding like this? i don't really off-road or anything.
    also, when i get a wider wheel with lower backspacing (4.25), since it will put the wheel farther from the ucas, will that make my tires look like they are leaning anymore?
  6. Aug 5, 2010 at 4:37 PM
    jandrews
    '09 FourDubDee TRD OR
    Positive camber is commonly used on vehicles that understeer (like 4wd trucks) because it makes steering easier. It will result in uneven tire wear though. Prefer my camber at zero and little heavier steering wheel.
  7. Aug 5, 2010 at 4:48 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    anything that will help me with this besides ucas? i don't have the $450+ that it's gonna cost for those right now. would a wheel with lower backspacing help with this? since it will give more room between the wheel and ucas
  8. Aug 5, 2010 at 5:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Wheel back space wont affect the camber. You need different UCA's to fix it. OR..Have your alignment guy set Camber at 0*, and live with crap Caster.
  9. Aug 5, 2010 at 5:20 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    what do you mean by that?
  10. Aug 5, 2010 at 5:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I mean your caster will be around .6*, as opposed to the 2.0* or so that it needs to be set at.
  11. Aug 5, 2010 at 5:24 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    and that will make my tires look right but give me a rougher ride or something of that nature?
  12. Aug 5, 2010 at 5:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Tires would "Look right", but the truck will wander. And thats if they can even get the Camber close to 0*
  13. Aug 5, 2010 at 5:29 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    alright, i'm just gonna have to ride like this until i save the money for better ucas. these should work, right? sorry for all the questions, but thank you
  14. Aug 5, 2010 at 5:32 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    What kind of lift u got?
    NM I see 2.5 spacers.
  15. Aug 5, 2010 at 5:33 PM
    justin14200
    justin14200 frequent reader
    justin
    baton rouge
    2010 prerunner sr5 bsp
    stock
    i have some builtright uniball ucas with procomp 3" ultimate lift kit runninig 17x8.5 atx thugs with 265/70r17 duratracs. i did the alignment at work and got every thing set to .0
    before the uca i couldnt force anything better than .4
  16. Aug 5, 2010 at 5:33 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    2.5" spacers, 2" aal
  17. Aug 5, 2010 at 6:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Those would be fine.
  18. Aug 5, 2010 at 6:09 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    great, thanks
  19. Aug 5, 2010 at 6:22 PM
    ColtsTRD
    Scott
    AZ
    I'm rockin' these and there great! My alignment specs are perfect with no issues :)
