tires rub after light racing uca install and align
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07TaCo07, Aug 8, 2011.
  1. Aug 8, 2011 at 11:33 AM
    07TaCo07
    07TaCo07 [OP] Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    I just installed some lr uca's and got an alignment and now the tires rub on the fender by the body mount. It is super annoying. Anyone have any ideas on what I need to adjust to fix?
  2. Aug 8, 2011 at 11:38 AM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    The devil is in the details.
    What lift? What size tires? What setting on the UCAs?
  3. Aug 8, 2011 at 12:00 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    X2, alignment spec sheet as well.
  4. Aug 8, 2011 at 12:01 PM
    07TaCo07
    oregon
    6in lift, 35s, driver side looks like its past the 4 degree and the passenger side is 4 degrees
  5. Aug 8, 2011 at 12:05 PM
    TexasTacoma37
    4 degrees of what? Camber? Caster?
    Rim specs?
  6. Aug 8, 2011 at 12:07 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    High caster will move the wheel back a little in the wheel well.
  7. Aug 8, 2011 at 12:55 PM
    07TaCo07
    oregon
    4 degrees is where the uca is set at. Ill try to post a pic of alignment specs
  8. Aug 8, 2011 at 1:04 PM
    07TaCo07
    oregon
  9. Aug 8, 2011 at 1:06 PM
    07TaCo07
    oregon
    No idea on rim backspace they were on there when I bought the truck
