Tires rub body mount after LR UCA install, will more castor help?
Discussion in 'Suspension' started by Dr.D, Jan 16, 2011.
  1. Jan 16, 2011 at 5:16 PM
    Dr.D
    Dr.D [OP] Well-Known Member
    sold my truck
    09 DC 3" lift LR UCA's URD TCAI
    3" lift Bilstein 5100's, small top plate spacer and poly spacer, 1" Block and TSB Springs in rear with 2.5 degree shims, MagnaFlow stainless exhaust, 275/70R17 BFG A/T 17x9 RBP wheels, Light Racing UCA's, PHILIPS 4300K HID, URD TCAI, 10" Kicker Comp, Advantage TorzaTop, Scanguage II, Foglight mod, Backup camera switch mod
    I searched and could not find the answer to my question.
    So I put Light Racing UCA's on my truck and since I did this I get tire rub on the body mounts when I hit a small bump while turning. Here are my alignment specs.
    Now my question is, if I increase my castor will that help stop this rubbing? I read some where that when you increase castor it pushes the tire more forward due to the how it adjusts from the lower control arm. Or do I have it backwards? Before the UCA's I did not have this rubbing.
  2. Jan 16, 2011 at 10:02 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    full lock? or while turning? going over bumps at the same time?
  3. Jan 16, 2011 at 10:03 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    yes. On my current application of 285 km2s I did not in normal driving with 2.6. I have mine set for 2.9 on both sides and have the body mount chopped.
  4. Jan 17, 2011 at 6:57 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    More caster actually moves the tire toward the rear of the fender so you would rub more with more caster. If you look at the tire from the side, the more caster the further the tire runs behind the axis of the upper strut mount.
  5. Jan 17, 2011 at 9:26 AM
    ktmrider
    Junk
    ^ actually the way I understand it, more caster tilts the spindle assembly towards the rear of the fender moving the tire forward.
    http://www.ozebiz.com.au/racetech/theory/align.html
    but the tilt they are talking about is in relation to the spindle so if it is backwards tilt the tire would actually be forward and + caster number.
  6. Jan 17, 2011 at 11:23 AM
    Dr.D
    sold my truck
    When adjusting the lower control arm for castor, wouldn't that move the lower control arm forward changing the axis and postion of the upper ball joint. Not moving the tire more towards the rear?
    I know that when my castor was at 1.6 before my UCA's I did not have this. So the increase in castor must move it more backwards I guess.
    jr114
    It doesn't rub at full turn, only while turning and hitting bumps or going up my angled drive way with my wheels turned.
  7. Jan 17, 2011 at 11:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes. If Caster is added via the UCA, then it will move it more tward the rear.
  8. Jan 17, 2011 at 11:31 AM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    + caster moves the tire forward, - caster moves it back. The further back it is, the better is steering is, however you need to find a compromise.
    My caster is 3.4 degrees with the body mount chopped and pinched. With 285's I still rub a little on the rear mount when flexed but not bad.
    In your case I'd try another degree forward from 2.3 to 3.3. Also get them to dial that camber to 0 or slightly negative.
    I've tried it all. 5 degrees is too much and you'll hit the front plastic, 2.6 is too far back, so I've found the best success with 3.2-4 degrees caster.
  9. Jan 17, 2011 at 12:14 PM
    Bama_TACO
    Winfield, AL
    Here's the deal. A good example of positive caster is the front wheels of a shopping cart. Notice how they follow the direction the cart is going. It's because the center of the wheel is behind the mounting point. If a UCA is used to get more caster it would move the ball joint toward the front of the truck. If the lower control arm is used to increase caster you would move it toward the rear of the truck.
  10. Jan 17, 2011 at 12:48 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I was just in the same boat as OP. I was starting to rub drivers side on the rear fenders by the pinch weld. Took it in and caster was 1.5 drivers side and 3 passenger. There was my answer. Already had the cab mounts chopped and still did the pinch weld mod since I off-road frequently. I would say chop them....you won't even notice! And get your caster at least 3.
  11. Jan 17, 2011 at 12:54 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    well here is my set up i have the ball joints adjusted +2 foward....
    and was able to obtain perfect #'s with no body mount rubbing
    'with no chop"
  12. Jan 17, 2011 at 1:01 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    There you go OP!
    You guys have the same uca's?
  13. Jan 17, 2011 at 1:02 PM
    Dr.D
    sold my truck
    Bama and BenJammn you guys said two different things. Which is correct?
    Postive castor with adjustment of the lower control arm will move the tire to the rear or front of the truck. Front right? And the LR upper control arm moves it towards the rear.
  14. Jan 17, 2011 at 1:07 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
  15. Jan 17, 2011 at 1:08 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    i am at -2.0 on each side
    ball joint rotated all the way to front.....
    no rubbing anymore with some front fender trimming.....
    and i have wheeled it many times hard....
  16. Jan 17, 2011 at 1:53 PM
    Bama_TACO
    Winfield, AL
    This is what I was saying. Below is using the upper control arm (not stock) to adjust caster. Moving the upper mount forward increases caster. If you are using the lower control arm for adjustment, moving the control arm rearward increases caster.
  17. Jan 17, 2011 at 2:15 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  18. Jan 17, 2011 at 5:32 PM
    Bama_TACO
    Winfield, AL
    Ok, your illustration and this one I found below prove that I am completely backwards in my thinking.
  19. Jan 17, 2011 at 6:19 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    ^No worries friend, you get the picture now
  20. Jan 17, 2011 at 6:25 PM
    jandrews
    '09 FourDubDee TRD OR
    Caster will help but probably not eliminate the problem. High amounts of flex and lock just put the tires into the cab mounts. Best solution is to chop and box.
