tires rub UCA with stock wheels
Discussion in 'Wheels & Tires' started by Tacoma2nd, Feb 1, 2011.
  1. Feb 1, 2011 at 1:56 PM
    Tacoma2nd
    Tacoma2nd [OP] Active Member
    06 prerunner
    2.5 inch coil spacer and rear add-a-leaf
    I have an 06 tacoma with 2.5 inch coil spacers and an add-a-leaf in the back. Im running 295/75/16 BFG all terrains on my stock wheels now and they rub the UCA. If I get 16x10 wheels with 4'' backspacing, will that stop my tires from rubbing? thanks.
  2. Feb 1, 2011 at 2:04 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    yes that will fix the problem :)
  3. Feb 1, 2011 at 2:08 PM
    tacosupreme54
    tacosupreme54 Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    or you can get wheel spacers if you want to keep your current wheels. post up some pics of your truck! i wanna see the 295's on 2.5'' in the front!
  4. Feb 1, 2011 at 2:09 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    With a 10" wheel, you might get some rubbing issues on the UCA. Not positive though. Might want to do a little more research before you decide to purchase.:cool:
  5. Feb 1, 2011 at 2:32 PM
    Tacoma2nd
    06 prerunner
    thanks guys. ill post pics as get some.
  6. Feb 1, 2011 at 2:34 PM
    Tacoma2nd
    06 prerunner
    do yall know where i can get some black 16x10 6 lug wheels for a good price?
  7. Feb 1, 2011 at 2:41 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Why do you want 10" wide rims?
    As per the BFG website, the 295/75/16's should only be run on rims 7.5-9.5" in width.
    Go with 16x8's or 16x9's, with 4.5" backspacing, and you will clear the uca fine.
    Or, get wheel spacers like TacoSupreeme suggested.
  8. Feb 1, 2011 at 2:42 PM
    Tacoma2nd
    06 prerunner
    no reason really. Thanks for the advice man.
  9. Feb 1, 2011 at 2:45 PM
    TexasTacoma37
    No problem. Just a note though: the new wheels or spacers will cure the UCA rubbing, but you may still rub on the fender well plastic and/or the cab mount, which I'm guessing you already do....
  10. Feb 1, 2011 at 3:17 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    pro comp has nice black wheels wheels for a good price. and wheel spacers will be cheaper than buying all new wheels.
  11. Feb 1, 2011 at 3:30 PM
    Tacoma2nd
    06 prerunner
    my tires actually dont rub anything except the UCA so new wheels or spacers will hopefull cure all rubbing problems.
  12. Feb 1, 2011 at 3:33 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    good shit. so you have no rubbing, other than the ucas, on only 2.5''? what did you have to trim?
  13. Feb 1, 2011 at 3:36 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    That might not be true when you move the tire out more you run into rubbing issues in the fenders.
    Edit: and how much did you cut already 295's are pretty big for a 2.5" lift.
  14. Feb 1, 2011 at 3:47 PM
    Tacoma2nd
    06 prerunner
    i didnt cut anything. they just dont rub anything but the uca
  15. Feb 1, 2011 at 4:29 PM
    Tacoma2nd
    06 prerunner
    do yall know what the stock wheel width and off set is on 06 tacomas?
  16. Feb 1, 2011 at 4:33 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    7.5" and eagle alloy makes a sweet 16x10 rim, I believe its series 185
  17. Feb 1, 2011 at 4:56 PM
    TexasTacoma37
    Stock backspacing is 5.5
  18. Feb 14, 2011 at 5:34 PM
    Tacoma2nd
    06 prerunner
    do any of yall know where i can get the TRD center caps?
