Tires rubbing after alignment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UmbrellaTaco, Mar 17, 2018.
  1. Mar 17, 2018 at 7:39 PM
    jca
    jca Well-Known Member
    If you can get your caster to 4 degrees, you'd be off to a great start. I have mine set to that and the taco drive great and doesn't rub.
  2. Mar 17, 2018 at 8:23 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Yeah, when I installed my new C/O's and UCA's I maxed out lower cams for most caster, set SPC's at neutral (2*), set camber to 0, set toe to 0 all so the tech would have as little to do as possible. I won't use a shop for confirmation anymore since it's so easy to do myself. I don't understand how some of these techs have all this high tech equipment and can't get it right.
    DavesTaco68 likes this.
  3. Mar 17, 2018 at 8:32 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The equipment doesn't make the alignment better or more accurate. All it does is make it so the tech is now expected to do more alignments in the same amount of time, he doesn't get to slow down and make sure it gets done right, it's go go go
    Like I said, shops that know what it takes to do a good job will be stubborn about getting paid. Shops that don't care will lure you in with a cheap price, get it "close" and move on to the next one. They simply don't have time to do it right because the only way they can stay profitable is to cram as many alignments through as possible
  4. Mar 17, 2018 at 9:20 PM
    UmbrellaTaco
    UmbrellaTaco [OP] Active Member
    Jon
    14 AC 4WD Taco
    Understood. LA (lower Alabama) lacks a shop that’s that meticulous. The shop I went was the most liked, the other option was the dealer. Regardless. I will attempt to do it myself tomorrow. Will update.
    MolonLabeTaco and b_r_o like this.
