Tires rubbing cab mounts after UCA
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dryvah, Mar 8, 2020.
  1. Mar 11, 2020 at 5:51 AM
    #41
    Sungod
    Sungod Well-Known Member
    St Augustine
    Ah, my favorite Boatswain's mate (or where you a Boiler tech?) chiming in. Not really sure what you point is except ignorance. I have threads on my shock body. Are you saying I should be concerned? Allow me to educate you that ICON makes an aluminum UCA that many people run here without issue. Hell the Bilstein's 5100 spring perch is held in place by a thin aluminum clip. I doubt you are aware, but those fully adjustable control arms are designed for a vehicle with a v8 with a steel block and heads easily weighing in at 1000lbs more than a Tacoma. I suggest you jump on a muscle car forum and tell them that you have deemed that configuration inferior and tell SPC that they should stop making them.
    Who knows, maybe you are right that we have pushed the limits of innovation and we have exhausted all ideas? As the great Rogers and Hammerstien shared with us "Everything's up to date in Kansas City, They gone about as fer as they can go"
  2. Mar 11, 2020 at 6:01 AM
    #42
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I thought they were very interesting, the adjustable uca. Buts let’s also remember the muscle cars you speak of usually are only going in straight lines, so while there is plenty of force applied to the arms it’s not the same so that is not a good comparison in any way.
    stun gun and Skydvrr like this.
  3. Mar 11, 2020 at 6:57 AM
    #43
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I thought 5100's had a hardened spring steel snap ring?
    stun gun likes this.
  4. Mar 11, 2020 at 7:11 AM
    #44
    Sungod
    St Augustine
    Could be, but the point is it super thin.
  5. Mar 11, 2020 at 8:00 AM
    #45
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Yeah but it's in shear, it'd be like trying to cut that snap ring w scissors.
    ericvega, GreyBaldTaco and stun gun like this.
  6. Mar 11, 2020 at 9:28 AM
    #46
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Big difference in off road applications.
  7. Mar 11, 2020 at 9:34 AM
    #47
    stun gun
    Aaronski
    Tacomas.
    Maybe I am right, yes. Only one way to find out. Get em made and put em through their paces. :popcorn: I got all the popcorn.
    GreyBaldTaco and Omar RVA like this.
  8. Mar 11, 2020 at 9:56 AM
    #48
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    The manufacturers of those UCAs make forged steel UCAs for off road use. You should call them up and explain to them how stupid they are.
  9. Mar 11, 2020 at 6:09 PM
    #49
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
    OP, Did you get anywhere with this yet? I just had new UCAs installed today and I’m having the same issue. Mine isn’t hitting the CM, but it’s a lot closer than it was with the stock UCA.
  10. Mar 11, 2020 at 6:43 PM
    #50
    hellfire0480
    hellfire0480 Well-Known Member
    Long Island
    2019 TRD OR Quicksand
    Eibach Pro lift, MR701, 285/70R17 AT3W, SOS Sliders, Sherpa RR
    I installed my JBA high caster UCAs this morning and drove it to the alignment shop. On the way there it was rubbing like a mfer. I was turning heads but not in a good way. I wasn't rubbing near as bad on the OEM UCAs.
    Got the alignment done and it is good to go. I haven't stuffed the tires yet but plan to soon to see if I need to CMC or just trim. Running 285/70R17 with a 17 x 8.5 0 offset.
  11. Mar 11, 2020 at 6:46 PM
    #51
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    I have jba high caster UCAs and same size tires but 17x9 -12 offset and no rubbing. Yours should definitely not rub. Check alignment sheet and see if caster is set to 4+ degrees and you won’t need to cut anymore.
    hellfire0480[QUOTED] likes this.
  12. Mar 11, 2020 at 6:47 PM
    #52
    hellfire0480
    Long Island
    Yep caster is above 4 deg on both sides. When I said good to go I meant I am not rubbing after alignment.
  13. Mar 11, 2020 at 6:49 PM
    #53
    newdles
    Achmed
    Ahhh ok. Yeah I sounded like an drunk angry machine gun driving to alignment shop after installing the jba UCAs. Thought I was going to rip something off my truck.
  14. Mar 11, 2020 at 7:05 PM
    #54
    hellfire0480
    Long Island
    Yeah it was sketchy. I decided to pass on stopping for lunch on the way there because that would have been quite a few more added turns :rofl:
  15. Mar 12, 2020 at 5:57 AM
    #55
    TacoTime850
    2019 DCSB 4x4
    I also have 285s, 17x9 wheels with -12 offset. I’m not rubbing but the tire is definitely much closer to the CM than it was before I had the Icon UCAs installed. The alignment feels really great. The tech said that he would put the caster as high as possible which should be around 4 or so. But did that high caster place the tire closer to the CM? How do I get the tire to move more forward? It’s too close to the CM for my liking.
  16. Mar 12, 2020 at 12:58 PM
    #56
    gotoman1969
    It did Not place it closer the the cm, what did was the the new wheel width and offset, because the scrub radius is in an entirety new spot.
  17. Mar 13, 2020 at 2:34 PM
    #57
    TacoTime850
    2019 DCSB 4x4
    This is probably already known, but I just found out why the tires rub with aftermarket UCAs. I called Icon, they said that the built-in caster meant to improve alignments pushes the tire closer to the CM or rear fender well area. So, my dilemma is resolved. I have about 4.5 caster and my drivers tire rubs on CM when the tire turned in reverse only. I had zero rubbing with stock UCAs.
    To fix this I guess you have to have adjustable aftermarket UCAs.
    plasticsnaks and Sungod like this.
  18. Mar 13, 2020 at 2:36 PM
    #58
    Dryvah
    Dryvah [OP] Well-Known Member
    MA
    2019 Tacoma TRD
    I decided to swap my 887s with 886s before I get the alignment done. Im swapping the coils tomorrow then getting it aligned Tuesday.
  19. Mar 13, 2020 at 2:38 PM
    #59
    gotoman1969
    I’d double check your alignment with 4.5 degrees you shouldn’t rub. What size tire are you running?
  20. Mar 13, 2020 at 2:40 PM
    #60
    TacoTime850
    2019 DCSB 4x4
    Maybe you’ll have different results, but my front lift is about .25” higher now with the new UCAs and new coilovers and it just now started rubbing after the aftermarket UCAs were installed. With stock UCAs I had about 1.5” of clearance and now I have about 2mm.
    Aftermarket UCAs really push that tire back towards the CM. My fingers are crossed for you.
