Tires rubbing fender, what to do?
Discussion in 'Suspension' started by fsbrain03, Mar 5, 2010.
  1. Mar 5, 2010 at 4:59 AM
    fsbrain03
    fsbrain03 [OP] Well-Known Member
    I put on my new spacer, and 33's last night (at least one side). The tires is running into the back of the fenderwell when i turn. What is the best way to fix this? I am sure there is a saw blade some where in my future, but I am also sure someone else has done the same. Just want to get some ideas. The total lift in the front is 3 inches, running goodyear mt/r.
  2. Mar 5, 2010 at 5:01 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    more lift or 32" tires..........:D
  3. Mar 5, 2010 at 5:06 AM
    fsbrain03
    Not really an option. I already have the tires, and I did not buy them local. I am pretty sure others have added 33's to their trucks.
  4. Mar 5, 2010 at 5:10 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    more lift or bust out the sawzall it is..........
  5. Mar 5, 2010 at 5:15 AM
    tanktodd
    tanktodd Well-Known Member
    Todd
    back on the right side of the bay, Ala
    08 Prerunner w/TRD Sport Pkg
    Limo tint in back w/ 20% on doors. Removed all badges. Stereo headunit, all new door speakers, 2 amps, and 10' sub...so far Black bullbar MotoMetals and 285/70/17 Duratracs. 3" OME springs in front and aal in back with tsb springs Black UWS tool box 5100's all around Plasti-dipped evo front end Fog light anytime mod OEM steps (for sale) HID fogs 55w 3000k HID heads 35 w 6000k "Cool white" dome & map lights
    I used a dremel and only had to trim maybe an inch and a half or so from front and back of fender on inside. Don't even notice unless you get down and look for it.
  6. Mar 5, 2010 at 5:15 AM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    Trimming the back plastic on the fender is the standard fix. If you take your time with it you can't even tell. I had 285/70/17s on almost no lift and with a little trimming they didn't scrub unless stuffed. Get a nice sharp razor blade and have at it.
  7. Mar 5, 2010 at 5:32 AM
    fsbrain03
    Great ideas guys. I am gonna try easiest first, but I am sure easiest will not work. Sawzall it is. Should have to take but an inch or so off, and then flare will cover that up. Aymore ideas let me know, gonna get back at it in about an hour.
  8. Mar 5, 2010 at 7:55 PM
    fsbrain03
    got it all fixed up, with minor body work, and no sawzall was used.
  9. Mar 11, 2010 at 6:36 PM
    BlueSteel
    BlueSteel Well-Known Member
    James
    The Woodlands, TX
    09 Magnetic Grey Doublecab TRD Sport Debadged
    Camburg 4" Spindles, Icon CB 2.5 adjustables front and rear, Total Chaos Upper/Lower CAs, Alcan 5" Rear Leafs, Timbren Bumpstops, 5" SS Brakelines, 295/70/18 Nitto Trail Grapplers on 18" KMC Monsters, Grill Craft Black Mesh Upper, Predator Running Boards, All Pro Rear Bumper and Hitch, Wet Okole Covers, Toyota Roof Rack, Limo Tint, TRD CAI, TRD Exhaust, Weathertech Mats, Redline Hood Struts, Red Top Odyssey battery, BDF Light Bar, Foglight anytime Mod, Lo Pro QT Truxedo Tonneau cover, Rocky Mount Bike Pegs.
    I used a shop knife and heated the razor blade with a butane torch, it cut it perfect like butter. I have been getting some rub now on the rear of the front fender flare when I turn the wheel and the suspension is at a slight compression. I think it rubs more now after I just got another alignment.
    Anyone else getting the rub in the rear of the front fender flare?
  10. Mar 15, 2010 at 12:40 PM
    fsbrain03
    All's good now, with no problems. Alignment done.
    Well yestreday while offroading, I had a little rubbing, but I was pushing the truck pretty hard.
