Tires rubbing on fox resi's!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zombie Runner, Sep 14, 2010.
  1. Sep 14, 2010 at 6:27 AM
    Zombie Runner
    Zombie Runner [OP] Are these black helicopters for me?
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I installed my fox coilovers this weekend and today I noticed while backing up my tires rub on my resi's while backing up! damnit!!!!
    And I only have the stock rugged trails..
    I have a set of spidertrax sitting in the closet...I guess ill be putting those on now.
  2. Sep 14, 2010 at 6:44 AM
    pinktaco808
    pinktaco808 Hot Steppa
    spacers????
  3. Sep 14, 2010 at 7:02 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    what?
  4. Sep 14, 2010 at 8:06 AM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Where are they mounted? Pics? Might have to remount them to clear larger tires... even with spacers
  5. Sep 14, 2010 at 8:07 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Read more? He said he has a set sitting in his closet.....
  6. Sep 14, 2010 at 8:39 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    In the normal spot. im running stock tires. I had 285's on the last one and they didnt rub.
  7. Sep 17, 2010 at 9:10 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I think I figured out my problem. I may have mounted the resi brackets the wrong way. the front should point down and the back should be up. then the tire would clear it when I turn. Im gonna flip them tomorrow.
    I didnt even knew it would make a difference. but after looking at my pics from my old truck I guess thats the problem
  8. Sep 17, 2010 at 11:11 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    yea, it was bothering me that they were rubbing on these stock ass tires when they didnt rub at all on my 285's!
  9. Sep 17, 2010 at 11:16 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup
    A few bolts are different.
    your old wheels had different backspacing too.
  10. Sep 17, 2010 at 1:25 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    your right. but where these are rubbing on the resi is close enough to the very outer edge that if i swap the mounts around it will be able to clear. 99% sure ;)
    If murphy is reading this........well I just hope he isnt.
  11. Sep 18, 2010 at 12:20 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I swapped them around and no more rubbing.
    but I have been hearing some weird squeaking coming from the suspension. I found out the sway bar is rubbing on the driver side CO now....:facepalm: if its not one thing its another....damnit
    I ordered the relocation brackets for the sway bar to correct the issue
  12. Sep 18, 2010 at 12:30 PM
    TacomaDan
    TacomaDan Don't go off ninjin
    Daniel
    Woodland, CA
    1996 Toyota Tacoma Fully Not Loaded
    Love, Cobra 29 LTD BT CB w/ A2000 Highgear antenna, FOX/Fabtech Coilovers, Magnaflow
    Remove swaybar FTW!!!!
  13. Sep 19, 2010 at 11:13 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I thought about it, I did on my last truck....but 90% of my driving is on the hwy so Im gonna keep it on. I should have the relocation brackets in a few days and I should be good to go
