Tires rubbing on frame?
Discussion in 'Wheels & Tires' started by tristen, Sep 26, 2012.
  1. Sep 26, 2012 at 7:53 PM
    tristen
    tristen [OP] Well-Known Member
    Tristen
    Georgia
    04 Prerunner
    I have a 2004 2wd prerunner. I have some 265/70/16 tires that aren't even necessarily all terrains but they rub on the frame a little bit. I know there is no harm in that, but what kind of issues would i run into when upgrading 265/75/16 duratracs?
    If they rub would a leveling kit help or what should i do?
  2. Sep 26, 2012 at 7:54 PM
    Bennett707
    Bennett707 TWSS Enforcer
    Oregon
    '04 V6 3.4 TRD
    zip ties and scotch tape
    I run 285/75/16 and rub frame, sway, and had to cut plastic over the pinch weld.
    I am sure you will rub frame and probably a bit of plastic. Not 100%
  3. Sep 26, 2012 at 7:55 PM
    tristen
    Tristen
    Georgia
    04 Prerunner
    It won't do any damage to the tires, right? And would a leveling kit be beneficial or make it look any better?
  4. Sep 26, 2012 at 7:55 PM
    Bennett707
    Oregon
    '04 V6 3.4 TRD
    Are you lifted at all? should have been first question.
  5. Sep 26, 2012 at 7:56 PM
    tristen
    Tristen
    Georgia
    04 Prerunner
    I forgot to mention being all stock..
  6. Sep 27, 2012 at 6:15 AM
    Tenax
    Tenax Well-Known Member
    Terry
    Alberta
    03 prerunner trd
    17 inch wheels
    Tristen, surprised the 270. 16s rub as that's a stock pre runner size. I ran that size with zero rub. So maybe your shocks need replacement? And you may find you're sidewall gets uncomfortably close yo the upper control arm with the 75 vs 70
  7. Sep 27, 2012 at 6:35 AM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    I'm surprised they rub too. My 265/75 BFG all terrains rubbed the frame a hair before the bilsteins
  8. Sep 27, 2012 at 6:44 AM
    Tenax
    Terry
    Alberta
    03 prerunner trd
    17 inch wheels
    I had zero rub on my 2003 pre runner that had 65,000 city/highway miles with an AT profile nokian 265 70 16 tire. I have nitto terra grappler 265 70 17s now and I think they only rub my wheel well/flap at full lock due to needing to put on spacers. They would have been in contact slightly with my Uca. And I have no lift added.
  9. Sep 27, 2012 at 5:24 PM
    tristen
    Tristen
    Georgia
    04 Prerunner
    Well my dad bought the truck for me wrecked and it was repaired, so that could have something to do with shocks?
  10. Sep 27, 2012 at 8:48 PM
    Tenax
    Terry
    Alberta
    03 prerunner trd
    17 inch wheels
    Could mean something...or nothing. What's the mileage on it?
  11. Sep 30, 2012 at 6:39 PM
    tristen
    Tristen
    Georgia
    04 Prerunner
    about 73000 miles. Would a leveling kit prevent the rubbing?
  12. Oct 3, 2013 at 6:23 PM
    Dietter700
    Dietter700 Well-Known Member
    Troy
    Montgomery County PA
    Taco TRD off road
    A leveling kit won't help the frame rubbing issue. It will help if there is rubbing on the fender well or body but not frame . IMO
  13. Oct 3, 2013 at 7:03 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I can assure you the rubbing will get worse once you get Duratracs.
