Tires rubbing on UCA
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JakeDaSnake17, Apr 27, 2018.
  1. Apr 27, 2018 at 12:23 PM
    JakeDaSnake17
    JakeDaSnake17 [OP] Member
    2013 Tacoma TRD Sport 4x4
    I had been reading some threads and was under the impression that 275/70r17 would fit on my 2013 tacoma. I have 1.75in bilstein 5100 adjustable in the front and the tires are sitting super close to the uca and also rub bad on turns. I'm on the stock 2013 TRD sport rim. If I drop down to a 265/70r17 will that fix my problem?
  2. Apr 27, 2018 at 12:25 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    What does your alignment look like ?
  3. Apr 27, 2018 at 12:31 PM
    JakeDaSnake17
    Alignment is good just got it done!
    And it is close close when tires are straight and rubs on the turns
  4. Apr 27, 2018 at 12:34 PM
    anthony250f
    Anthony
    San Diego, CA
    Well what are the numbers on the alignment ? What’s the castor ?
  5. Apr 27, 2018 at 12:34 PM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    When I lifted my truck I had to get spacers to keep my tires from rubbing on my UCAs, and I have 255s. Idk if second gens have similar issues, but the spacers fixed them.
  6. Apr 27, 2018 at 12:40 PM
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Factory UCAs? Aftermarket UCAs will give you a touch more clearance, and you’ll want a wheel with more of a negative offset
  7. Apr 27, 2018 at 1:02 PM
    JakeDaSnake17
    I do not know the numbers on the alignment or castor or what that is to be honest.
    I'm trying to avoid spacers heard too much negative about them.
    As for the wheel what is the stock offset and what should I be looking to get as far as a negative offset.
    txtaco87 likes this.
  8. Apr 27, 2018 at 1:04 PM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    The biggest tire you can fit on a stock rim without spacers, aftermarket UCA, or trimming is the 265/70r17.
  9. Apr 27, 2018 at 1:05 PM
    JakeDaSnake17
    Even if I change the wheel to one with more negative offset than the stock
  10. Apr 27, 2018 at 1:06 PM
    SocalTaco15
    Glen
    That would do it too. Proper Backspace is your friend.
    txtaco87 and Seabass like this.
  11. Apr 27, 2018 at 1:08 PM
    JakeDaSnake17
    So if I get a new set of wheels with more negative offset I should be okay with these tires? Correct? How much of a difference is between the sizes? I love the height and look of this
  12. Apr 27, 2018 at 1:10 PM
    Spencer4x42006
    Spencer4x42006 Whoisthatguy
    Spencer
    Bend, OR
    2006 TRD OR
    5100s Wildpeaks Light bar Other shit
    You could cab mount cop and get some spidetrax, I'm on OR rim so they 16 but that worked for me.
    Aarophi likes this.
  13. Apr 27, 2018 at 1:14 PM
    JakeDaSnake17
    It's not hitting plastic or cab just the UCA.
  14. Apr 27, 2018 at 1:21 PM
    Spencer4x42006
    Spencer
    Bend, OR
    2006 TRD OR
    Then I'd look into a spacer if you aren't looking to spend the $$ on new rims. Bora and spridertrax are the best brands around with the guys that run them, stay away from that lugcentric eBay shit. They break.
  15. Apr 27, 2018 at 1:41 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Bora .75
    Torque properly and you can forget about them. The studs will stick out a little but your factory alloys should have a little pocket between each lug hole.
    SocalTaco15 likes this.
  16. Apr 27, 2018 at 1:45 PM
    SocalTaco15
    Glen
    When I go up to that size, I’ll be running FJ Cruiser Wheels. They have 4.5” back space. They clear the uca.
  17. Apr 27, 2018 at 1:47 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Spacers SUCK. Get a 0 offset rim. Period.
  18. Apr 27, 2018 at 1:50 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Please explain
  19. Apr 27, 2018 at 1:59 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    They are another connection between wheel and hub, which isn't optimal. Another failure point. I see lots of people eventually ditching them. Etc. Etc. Do it right and get the right offset on rims and avoid them.
  20. Apr 27, 2018 at 2:36 PM
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    I ran spacers with an old set of rims for a while and I didn’t like how it rode and was sketched the f out by having one fail while driving. Bought a set of rims with 4” of backspacing (-10 offset) and zero issues
