Tires rubbing UCA on full turn
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wolcott, Jan 26, 2010.
  1. Jan 26, 2010 at 5:36 PM
    wolcott
    wolcott [OP] Active Member
    Snohomish, Washington
    05 Tacoma DBL Cab TRD Off-Road
    Hey all, I'm a noob here and this is my first post. I'm not sure if this has been answered somewhere else, but either way maybe someone can help. I've got an 05 Double Cab TRD Off Road and just did a 3" spacer lift in front and 2" AAL in rear. New tires are 285/75/16 on stock rims. While this looks AWESOME (i'm hoping to post pics soon in the Silver Taco thread) on full turns i get a little rub on the UCA's. Is this something I should learn to deal with, or would a new set of UCA's correct this? I see alot of ppl installing Total Chaos UCA's and other brands. Any help would be appreciated.
    Thanks!
  2. Jan 26, 2010 at 5:38 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    I have left mine alone. It doesnt hurt the tire, you just feel the vibes in the cab. TC or LR UCAs help with the alignments issues
  3. Jan 26, 2010 at 5:40 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    wheel spacers for stock wheels or new wheels with different offset.
  4. Jan 26, 2010 at 5:40 PM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    Boulder Creek, CA (Nor-Cal)
    2010 SSM DCLB
    I have my billy 5100's up to 2.5" and they rub at full turn as well. It doesn't seem like it's that big of a deal to me if you aren't doing it constantly. The TC UCA's/LR UCA's will help with the issue and if you have the money go for it
  5. Jan 26, 2010 at 5:40 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    new wheels with more Back spacing and uca's would do the trick. There are plenty of guys on here running stock uca with 285's . you will rub some.
  6. Jan 26, 2010 at 5:41 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    doesnt hurt the tire?
  7. Jan 26, 2010 at 5:42 PM
    Lentsnh
    Present and accounted for!!!:D
  8. Jan 26, 2010 at 5:43 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    add 1/4" spacer and it will rub less
  9. Jan 26, 2010 at 5:56 PM
    wolcott
    Thanks so much for the replies. I've heard some people aren't huge fans of spacers. What're the negatives?
  10. Jan 26, 2010 at 6:03 PM
    wolcott
    Lents, just checked out your build - Looks sick!!
  11. Jan 26, 2010 at 6:03 PM
    Lentsnh
    Nope just rubs... The stock UCA is smooth on the side, so it just slips by
    It can ruin your wheel bearings and put extra stress on the lug bolts
  12. Jan 26, 2010 at 6:04 PM
    Lentsnh
    Thank You!! :D
  13. Jan 26, 2010 at 6:12 PM
    johnw
    john
    orlando florida
    could you explain to me how they are dangerous? they are safer than the spider trax adapters
  14. Jan 26, 2010 at 6:16 PM
    wolcott
    Thanks Mike - I'll probably look into the spydertrax. Do most guys do them only in the front? I'm just wondering how it would look to have the front wheels stick out a little more than the back. Maybe it's not that noticeable..?
  15. Jan 26, 2010 at 6:19 PM
    Lentsnh
    if you do a small width spacer then you most likely wont need all 4. But if you were going with a large width... Go get all 4.
  16. Jan 26, 2010 at 6:21 PM
    wolcott
    You guys are a great help, thanks so much. I've been looking at all your builds for the past few days and can't wait to empty my wallet!
  17. Jan 26, 2010 at 6:25 PM
    Lentsnh
    HAHA watch out its going to happen.... FAST!;)
  18. Jan 26, 2010 at 6:30 PM
    Lentsnh
    If you offroad alot or on occasion but give no mercy (or both) then just get new wheels.
    If you do either or both with Spidertrax adapters/spacers, you can cause serious damage to you lug bolts, lug bolt threads, may cause the spacer to fail, and a higher chance of you wheel shedding the lugs.
  19. Jan 27, 2010 at 2:48 PM
    johnw
    john
    orlando florida
    this is true but my spacers are the correct ones. i offroad my truck hard and give it hell all the time. i have had them on since feb 2008 and no problems at all
  20. Jan 27, 2010 at 2:51 PM
    Lentsnh
    define correct ones. :confused:
    I havent heard of Spidertrax failing, but I have seen threads on here about those All-Pro wheel spacers failing. It happened not too long ago
