Tires rubbing UCA
Discussion in 'Wheels & Tires' started by TarzansTaco, Jun 8, 2017.
  1. Jun 8, 2017 at 10:29 PM
    TarzansTaco
    TarzansTaco [OP] Member
    Isiah
    LA/OC/SD SoCal
    08 4x4 DblCab SR5 TRD OffRd TowPkg
    So my 265/75/16 falken a/t tires are rubbing on my UCA, what kind/size and how much do spacers run.
    Just got my taco two days ago
  2. Jun 8, 2017 at 10:33 PM
    tcjacado
    tcjacado Well-Known Member
    You can do 1 or 1.25 inches but spacers are not recommended. There are many opinions on them. Best to figure out why they are rubbing and fix uca, lca or spindle that maybe causing the issue. Just my opinion.
  3. Jun 8, 2017 at 10:36 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    I would see if someone local with a little more Tacoma experience can take a look at it for you, that size shouldn't be rubbing whatsoever on the uca, do you have pics of where it is rubbing? I have the same tires on my stock wheels and they don't rub at all. To your original question most people go with spidertrax because they are hub centric, spacers could on the other hand make you rub in different places, I don't know the smallest size they make assuming it's around 1.25.
    tcjacado likes this.
  4. Jun 8, 2017 at 10:38 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    When was the last time you had an alignment done? Also have you lifted the truck at all?
  5. Jun 8, 2017 at 10:40 PM
    mosquitoTaco
    Anthony
    SouthTennessee
    Ha ha, I don't think he lifted it only having it for 2 days, but If it was done already it could have been done wrong, good question :thumbsup:
  6. Jun 8, 2017 at 10:44 PM
    Allstar780
    Allstar780 Well-Known Member
    Colin
    Alberta, Canada
    15 TRD Trail Teams Sport
    3" Lift, 32" Goodyear Duratrac, XD Series Hoss Rims
    Look into what these guys mentioned but if you do end up looking at spacers, Bora makes a 3/4 inch...
  7. Jun 9, 2017 at 6:39 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Bad alignment is the only thing I can think of to cause that size tire on stock wheels to rub the UCA.
    It's doubtful he lifted it or put on a leveling spacer, but possible. That'll throw off the alignment.
  8. Jun 12, 2017 at 9:49 AM
    TarzansTaco
    Isiah
    LA/OC/SD SoCal
    Thanks guys. I put 1.25 spacers and fixed the problem. I also screwed up the tire size, they're 285/75/16.
    Another question. So I got a stock looking height now, more nose down than even. I'd like a 3in lift but in the military and don't have the money to spend on fabtech or procomp. Just looking for looks more than performance. I go off road maybe once every two months. Any suggestions?
  9. Jun 12, 2017 at 11:46 PM
    mosquitoTaco
    Anthony
    SouthTennessee
    Fabtech and procomp are actually both shit, very few may try to defend that, what you need to do first is try to find out what suspension you are on currently and then we could probably be able to help you out a little better from there. If you don't know what your running a lot can be figured out with pics
  10. Jun 13, 2017 at 12:03 AM
    tcjacado
    Even with the lift those tires are still goimg to rub most likey. Typically, you will need to do the cmc (cab mount chop). Tires will rub on that area unless you cut and weld in new plates. Most shops will do it for arounf 120.00, but you still have travel up issues in tot he fender flare and wheel well. Hammer pinch weld flat. Your answer to a decent lift is a set of bilstein 5100 adjustables in the front, set on next to highest level and put in a deaver aal (add a leaf) and keep the overload in. Bilstein Shocks, the deaver aal, new leaf center pins, cmc, and hammer pinch weld to solve rubbing issue. If it rubbing lca or uca then you may need to upgrade those as well. Or you can go to a smaller tire. Our tire width can not be more 10 inches wide or it rubs and mods need to be done. Gl with the decision to cut and hammer or go smaller.
  11. Jun 13, 2017 at 4:05 AM
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    Since you don't off-road much a spacer lift would work for you. Kits are around 150 to 250. UCA's would be needed if you go over 2.5 inches.
  12. Jun 13, 2017 at 4:08 AM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
  13. Jun 13, 2017 at 7:35 AM
    mosquitoTaco
    Anthony
    SouthTennessee
    Why would you suggest such things?
    For real though, he may already be lifted, we don't know
  14. Jun 13, 2017 at 8:25 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I started to post how the alignment does not cause or fix control arm rubbage.
    That the whole assembly moves together.
    AND, that OP either needs narrower tires, the correct BS on his wheels, or spacers.
    Then, I saw that he'd already gotten his answer. I figured why get involved :thumbsup:
  15. Jun 13, 2017 at 9:59 AM
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    Figure out what you already have and go from there. If it's easier, just take a picture of the front coilover assembly. We'll be able to assist you from there.
    If you're truck isn't lifted already, keep in mind you will need UCA's above 2". I'm sitting at 1.6" in the front right now and it's on the edge of needing UCA's. Spacers on top of the shock will provide lift but at the detriment of performance.
    The best bang for your buck is probably a set of Bilstein 5100's or OME shocks, new coils(Eibach, OME), an add a leaf, and UCA's. You'll be out around $1k but it will be done right.
    Kuntrykid likes this.
  16. Jun 13, 2017 at 7:49 PM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    That's the setup I'm going w/ as my suspension. Putting 285/75/16s on my stock suspension. Already have CMC plates ready to go!
    :thumbsup::mudding::oldglory:
  17. Jun 13, 2017 at 10:56 PM
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Lift: 885s, OME shocks, OME Dakar Leaf Pack
    I have 285/75/16 KO2s
    They rubbed my UCAs at first
    I got Spydertrax 1.25" spacers
    That got the rub off of my UCAs but then was on my cab mount.
    Chopped that (along with some fender well), haven't welded on new plates but I spray painted to defend against rust & most importantly there's no more rubbing
