Tires rubbing
Discussion in 'Suspension' started by Re8elmonk0341, Jan 19, 2009.
  1. Jan 19, 2009 at 11:21 AM
    Re8elmonk0341
    Re8elmonk0341 [OP] "Kill BABIES"
    m0nk
    Owasso, Oklahoma
    1st Gen. DC 4x4
    Anyone have an issue with your tires rubbing on the plastic part when they make a wide turn? Im just gonna cut that part off. wondering what some of ya'll think?
  2. Jan 19, 2009 at 11:34 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    what plastic part are you talking about?
  3. Jan 19, 2009 at 12:00 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    If it's where I think you're talking about, it's common for lifted trucks with oversized tires. And no, it's not a problem to cut.
    What size lift/tires are you running?
  4. Jan 19, 2009 at 12:11 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    cut cut cut cut cut cut away... :thumbsup:
  5. Jan 19, 2009 at 12:27 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Ah, the inner fender rub.
  6. Jan 19, 2009 at 12:35 PM
    longbow
    Bill
    Indiana
    If you are talking about the inner well, towards the front, those two buldges that hang down, you can cut them. I measured about an inch up and cut downwards at an angle.
    I also had to cut the flare at the very bottom, no biggie and have pic's to show where I cut it. Since these were done no rubbing at full turn L or R.
  7. Jan 19, 2009 at 12:39 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    longbow if you dont mind to throw those pics up where you trimmed the flare that would be great. I still have some rub somehow and was curious how far you trimmed the flares.
    thanks
  8. Jan 19, 2009 at 12:41 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    NM found it in your gallery.
  9. Jan 19, 2009 at 1:32 PM
    longbow
    Bill
    Indiana
    Dark Knight......I went over kill in the trimming of the flare, I seen the rub line and added an inch when I cut.
    Use the finest tooth saw you can find, those plastic model saws work the best, Tamiya or X-acto
  10. Jan 19, 2009 at 1:34 PM
    longbow
    Bill
    Indiana
    before....
    after
  11. Jan 19, 2009 at 1:35 PM
    LonghornTaco
    Minnesota
    Or a dremel... Cut like butta!
  12. Jan 19, 2009 at 1:39 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    yea I dremeled it before. Mine almost looks trimmed that much. It is just bugging me that I havent gotten it all to go away. but I also think I am still rubbing on the body mounts mostly but only when flexed, flying into a parking lot or something like it. But every once in a while it still sounds like plastic rub.
    thx for the pics
  13. Jan 19, 2009 at 1:45 PM
    longbow
    Bill
    Indiana
    On my last outing I heard the rubbing to. Stopped and got out. I was in a hard turn with alot of flex, I think you are right in the body mount location. I know the area where the rubbing is, but it's metal, most case when I do hear it, I turn the wheel just a little, still under flex and it goes away.
    Bad thing is I never have the camera with me when it happens. But I will get the area on film/memory card.
  14. Jan 19, 2009 at 1:52 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    yep its only in a certain spot under lots of flex. I think I have it calculated in my head that a 17/18 by 8/8.5 wheel with minimal negative offset and in between 4.5"/5" backspacing will solve this problem,.........maybe.
    The wheels I want to try this thought process with are the American Racing Thugs (17x8.5 -6mm offset and 4.53 BS) I dono well see when my money tree grows.
