Tires Rubbing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DucTaco, Nov 20, 2012.
  1. Nov 20, 2012 at 12:59 PM
    DucTaco
    DucTaco [OP] Well-Known Member
    2010 DCSB TRD OR
    Ladies and Gentlemen, this is my first post even though I have been trolling the forum since 2010. I apologize in advance if this isn't in the right spot but here goes anyway. I put SCS F5's with 265/75/16 BFG AT's on my stock 2010 DCSB 4WD last night and the tires are doing some pretty good rubbing upon turning. I was hoping that someone could inform me on the best and/or cheapest method to rectify the situation? Thanks for the help.
    I look forward to being a bit more active in the forum. Thanks again.
    D
  2. Nov 20, 2012 at 1:07 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    What is the back spacing on the wheels? Are you lifted?
  3. Nov 20, 2012 at 1:08 PM
    Manwithoutaplan
    ID
    You have any pictures of the rubbing ???
    I would get dermal and grind, when you have that go to town trim back plastic.
  4. Nov 20, 2012 at 1:11 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    [​IMG]Welcome to TW from Ferntucky, NV[​IMG]
    What are they rubbing on? Sounds like you ether need wheel spacers or a lift.
  5. Nov 20, 2012 at 1:18 PM
    DucTaco
    2010 DCSB TRD OR
    The tires are rubbing on the plastic in the rear of the well. Mostly the black flimsy plastic but some inside/lower white fender plastic. I hope that makes sense. It is not lifted and no spacers. Thanks for the replies.
  6. Nov 20, 2012 at 1:22 PM
    Manwithoutaplan
    ID
    Fyi if interested, I have 2 inch spacers if you want them $40 bucks their yours.
  7. Nov 20, 2012 at 1:36 PM
    DucTaco
    2010 DCSB TRD OR
    Manwithoutaplan, PM sent.
  8. Nov 20, 2012 at 1:37 PM
    Manwithoutaplan
    ID
  9. Nov 20, 2012 at 1:37 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    hey, with spacers you will rub more!!!!
  10. Nov 20, 2012 at 1:53 PM
    4Wheelin4Banger
    Randy
    Time to trim or lift.
  11. Nov 20, 2012 at 9:57 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Hey Andy
    The plastic liner rubbing you are experiencing is typical when you upsize in tire height. Don't be too alarm. Like most owners here, you'll have to look at where its rubbing and do a little cutting to achieve the needed clearance. It's a pretty straight forward job. Let me know if you need anything else.
  12. Nov 21, 2012 at 6:52 AM
    DucTaco
    2010 DCSB TRD OR
    Thanks for the help everyone. I really appreciate it. I got ahold of a Dremmel and will be doing some trimming later on today or this weekend. Thanks again.
  13. Nov 21, 2012 at 10:40 AM
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    Interesting, Anyone know why are there so many threads on this site saying that 265/75 size tires are the biggest you can go on stock rims without rubbing?
    That doesn't appear to be the case here. I'm wandering because I was going to replace my 265/70 stock tires with 265/75. I thought the rubbing wouldn't be an issue due to all the threads on this site, but now I'm not sure. Was also worried about ABS and Traction Control coming on pre-maturely.
    Aldarnell, do you notice any issues with your ABS or Traction Control after switching from 265/70 to 265/75 on stock rims? The manual seems to imply that these systems are tuned to your stock tire size and could be affected by changing and keeping the same rims.
  14. Nov 25, 2012 at 1:27 PM
    DucTaco
    2010 DCSB TRD OR
    As far as I know there has been no issue of tpms or traction control. Then again, I have only driven the truck 5 or so times since I put the wheels and tires on. (I was in Phoenix for the holiday) I did some cutting today with a dremel and all seems well but I am now missing one of the plastic rivets that hold the splash guard in place. Once that is replaced and I am driving to and from work all this week I will let y'all know if anything crazy happens. Thanks for all of the help everyone.
  15. Nov 25, 2012 at 1:29 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The OP isn't using stock wheels , no ?
  16. Nov 28, 2012 at 8:38 AM
    DucTaco
    2010 DCSB TRD OR
    I am not using stock wheels. I have the SCS 16's. I am doing a lot more trimming than I though I would have to do. Not that big of a deal to me. Once I finally don't hear any more rubbing, I will take photos of the inside of my fenders for reference for anyone who is planning on getting the same size BFG AT's. Again, thanks for the assistance everyone.
