Tires rubbing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rushdog, Sep 10, 2015.
  1. Sep 10, 2015 at 5:05 PM
    Rushdog
    Rushdog [OP] Member
    Brian
    2012 tacoma trd sport
    3" pro comp lift
    Just bought myself a 2012 trd Sport with a 3" pro comp lift.It has stock 18's with 275/70/18 cooper discoverer STT's.The tires are rubbing the upper a- arms on tight turns.Any suggestions on a tire size.I don't really want to put wheel spacers on.
  2. Sep 10, 2015 at 5:09 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Wheel spacers or different offset wheels. Welcome to the forum. I think the sports only came in 17" wheels but I do know 18's exist but probably on the limited.
    ManBeast likes this.
  3. Sep 10, 2015 at 5:42 PM
    Rushdog
    Rushdog [OP] Member
    Brian
    3" pro comp lift
    What about running a 265/70/18 tire.II plan on getting different tires anyway.I need something better for hiway driving.
  4. Sep 10, 2015 at 5:46 PM
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
  5. Sep 10, 2015 at 5:52 PM
    Rushdog
    Rushdog [OP] Member
    Brian
    3" pro comp lift
    Rims are oem.original tire size was 265/60/18.Now has 275/70/18's.I was hoping that going back to a 265 would eliminate the a-arm rubbing.Tires are very aggressive. That might be part of the problem.
  6. Sep 10, 2015 at 5:55 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Do you have aftermarket upper control arms? Not that it would help the rubbing, but at that height you definitely need them.
    Aggressive tires should not be a problem if they are the right size.
  7. Sep 11, 2015 at 6:48 PM
    SketchyTaco
    SketchyTaco Member
    2007 Tacoma V6 DC Prerunner TRD Sport
    I'm trying to avoid similar issues. Currently have stock 17" wheels, no lift, no spacers. Going to get Cooper Discoverer AT3 in 265/70/17. I'm told these fit with no rubbing and no mods required. I do want a wider stance. Thought of 1" spacers but hear they can cause problems, roughin road ride, etc. What wheel offset would be equivalent to 1" spacers??
    Stock 17" wheels have offset of 35mm (1.37"). I apologize in advance, I'm a little ignorant to all this terminology and just learning about wheels, lifts, and tires. But some help would be great. Not offroading, mostly for looks. And want less damage to my wallet without screwing up my truck
  8. Sep 11, 2015 at 6:56 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Wheel spacers do not affect ride. Suspension spacers do. I think the sport offset is 30? Minus 25.4mm/in to get an offset of 5 to push them out 1". A few TRD wheels are in this similar offset like mine and the SEMA TRD wheels.
  9. Sep 12, 2015 at 3:55 AM
    Rushdog
    Rushdog [OP] Member
    Brian
    3" pro comp lift
    I ordered a set of 265/70/18 to try out.I'm hoping this will achieve my goal.No rubbing and a little better fuel economy.
  10. Sep 12, 2015 at 8:15 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Did your tires rub anywhere else? Like the cab mount? 265/70R17 is the largest that will fit with no rubbing, unless the PO already did the trimming required to fit the larger tires.
  11. Sep 13, 2015 at 3:08 PM
    Johnny DemonT
    Johnny DemonT Well-Known Member
    SW Burbs of Chicago
    15 Silver DCLB
    Let us know how these work out please. Post some pix and specs. I am up in the air if I wanna try to run this size as well. Thanks.
  12. Sep 13, 2015 at 3:09 PM
    Rushdog
    Rushdog [OP] Member
    Brian
    3" pro comp lift
    Will do!
  13. Sep 16, 2015 at 5:00 PM
    Rushdog
    Rushdog [OP] Member
    Brian
    3" pro comp lift
    Don't have any pics as of right now,but I got General Grabber AT2. 265/70/16's.No more rubbing and the ride is really good.
    Johnny DemonT likes this.
  14. Nov 22, 2015 at 1:07 PM
    AZDesertTRD
    AZDesertTRD Well-Known Member
    Pamela
    Arizona
    2012 PreRunner Sport
    Op are you running 16's or 18's?
