Tires shaking like crazy!
Discussion in 'Wheels & Tires' started by cannonman93, Mar 9, 2013.
  1. Mar 9, 2013 at 7:11 AM
    cannonman93
    cannonman93 [OP] Member
    Texas
    09 Tacoma access cab base
    I have a 09 access cab 2 wheel drive 92,000 miles, I bought new bilstien 4600 shocks and struts from 4 wheel parts and had them installed by a mech, tires shaking, I bought new tires 225/70/15, still shaking, I bought new MB TKO 8" wheels with the x lugs to seat the rims properly, still shaking. I have had two different mech look at it and both say nothing wrong?. I had all part numbers checked and everything is correct. Had tires balanced 3 times, still shaking!, last resort I am going to toyota monday. Any suggestions?... I am at a total loss!!!
  2. Mar 9, 2013 at 7:18 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    This is a fairly common problem. It usually has to do with the aftermarket wheels not being HubCentric, like stock wheels are. Also, Road Force balancing of the tires have helped some.
    Also, I want to see pics of a 15" wheel on an 09. :popcorn:
  3. Mar 9, 2013 at 7:30 AM
    cannonman93
    Texas
    Road force balancing?.... the stock tires that came on the truck were, 205/75/15
  4. Mar 9, 2013 at 7:36 AM
    Davtopgun
    David
    Central Alabama
    My bad, I was assuming you had a 6 lug truck. I realize now that you have a 5 lugger.
    Yes, Road Force Balancing is a pressure type tire balancing method that has solved the problem for many. It's not the common balancing type, you have to find a shop that does it. No guarantee that it will work, but it's an option. I eventually got lucky on my 07, and after a road force and a good alignment, the vibration was pretty much gone.
  5. Mar 9, 2013 at 7:38 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    So it didn't shake until shocks and struts, or when did the shaking start?
    If it started with shocks and struts I'd work backwards from there.
  6. Mar 9, 2013 at 7:38 AM
    cannonman93
    Texas
    Ok, I love the truck but the shaking is driving me crazy, I will ask about the force balancing issue...
  7. Mar 9, 2013 at 7:45 AM
    cannonman93
    Texas
    It has had some shake with the new shocks but went off the deep end with the new tires and wheels. Both mech's that looked at the truck said the struts and shocks are not the issue. No bad front end parts either.....
