Tires, should I go back to OEM size?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dward, Jan 15, 2022.
  1. Jan 17, 2022 at 6:45 PM
    riverrat958
    riverrat958 Well-Known Member
    keith
    upstate ny
    2015 base crew cab tacoma
    camera source backup, camera seat covers,intermittent wiper arm
    just replaced my tires-2015 -4cyl 4x4 245/75/16 I stayed with those
  2. Jan 17, 2022 at 6:56 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    I may be wrong but I *think* 4-cyl trucks used that narrower tire. Maybe something to do with slightly lower rolling resistance to go with lower power output of a 4-cyl engine.
  3. May 12, 2024 at 3:57 AM
    terryhutchinson
    terryhutchinson Well-Known Member
    Terry
    2023 Tacoma TRD Off Road
    4 cyl Tacomas come with the 245s because all of the lower trim models (non-TRD) come with 245s. I am currently planing to replace my 265/70/R16s with Michelin Defenders and am still debating in my head the 265/70 and 245/75 question. I think it likely makes no difference whatsoever in perceived performance. Just curious if the slightly narrower, and lighter, tires would make a difference in fuel economy.
    Going up a size to 265/75s is not a consideration for me because how a tire looks is not a relevant consideration when choosing tires.
  4. May 12, 2024 at 4:55 AM
    bartender138
    bartender138 Active Member
    Ed
    North Shore MA
    2009 2.7L 5M access cab
    I know this is an older thread that’s been resurrected but I too am facing this dilemma- I’ll need new tires soon and have the stock size (245/75/16) Falken Wildpeaks at3 that were on the truck when I bought it. Other than aesthetics, is there a benefit to the 265’s? It’s a daily driver that sees snow and an occasional dirt/gravel road but no real off-roading.
  5. May 12, 2024 at 5:26 AM
    216to404
    216to404 Well-Known Member
    2006 RC prerunner
    On fresh powder and deep, clean snow pack taller, narrower tires are generally preferred. For hardpack snow, slush and ice mix, shorter and wider tires aired down a bit are generally preferred.
  6. May 12, 2024 at 6:59 AM
    Agoldxj
    Agoldxj Well-Known Member
    James
    Central Pa
    2009 SWB AC
    I’ll have a set of 265/70/16 Falken Wildpeak at4s for sale tomorrow with 4K miles on them. I’m sure gas or shipping would kill the deal though.
    bartender138[QUOTED] likes this.
  7. May 12, 2024 at 7:27 AM
    bartender138
    Ed
    North Shore MA
    if I was a little closer I’d seriously consider your offer. Thank you anyway
  8. May 12, 2024 at 7:38 AM
    Agoldxj
    James
    Central Pa
    2009 SWB AC
    No worries, I’d stick with the larger tires if anything just for cosmetic reasons.
  9. May 12, 2024 at 7:51 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    About 3 years ago I went from larger oversized tire to new, almost zero mile set of 2021 takeoffs. 2006 TRD OR, Compared to the prev tire the reduction in tire noise was significant and the OEM had far better highway manners and mileage was better. Fast forward 3 years and I bought the 265 Wildpeaks to replace the OE tires, there wasn't a big increase noise, the mileage probably suffered slightly, it wasn't significant and the ride with wildpeaks to me was just as good as the OEs for whatever that's worth.
  10. May 12, 2024 at 8:28 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Interesting, I thought it was the opposite. I thought narrower was generally better for every application except those where you want flotation (like powdery snow).
    I think people usually clarify that 265 isn't really a wide tire, either. 255's are considered narrow, 285 starts getting into the wide realm, from what I've seen.
  11. May 12, 2024 at 9:48 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Another thing to consider and I don't think it's that great of an issue here is that with the wider tires, you will have slightly, I say slightly fewer pounds per square inch of weight of surface contact and if you live in the rust belt it may make a slight difference in snow and ice. Soft surfaces like mud and sand, wide tires can be an advantage.
  12. May 12, 2024 at 9:52 AM
    Schlappesepple
    Joe
    2020 4Runner ORP
    That's another point I forgot: the different sizes will call for diff pressures. Should be 29 psi for the 265, but your door frame should tell you the pressure for the 245s.
  13. May 12, 2024 at 10:36 AM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    I run 32~33, came back from the tire store with 36 which was harsh but got good mileage, I've switched to back down to 33, seems to be a happy medium between ride quality and mileage.
  14. May 12, 2024 at 10:51 AM
    XSplicer62
    Jefferson State
    About the same here, running 32 in my 265/75s. :thumbsup:
  15. May 12, 2024 at 2:35 PM
    #35
    216to404
    2006 RC prerunner
    I’m sure there are as many thoughts on this as there are types of snow :)
    I was always taught (and drove up north) that you want to cut through the fresh powder and get deeper into the firmer packed snow underneath the powder, and that narrower tires are preferred since the narrower contact patch kind of slices through the powder more effectively.
    But I could also see like 4’ of fresh pack you’d want as wide as you could since you couldn’t reach the hardpack 40” down.
