Tires Skidding
Discussion in 'New Members' started by Trd sport 2010, Sep 19, 2010.
  1. Sep 19, 2010 at 4:42 AM
    Trd sport 2010
    Trd sport 2010 [OP] TRD SPORT!
    Nik
    Richmond va
    2010 trd sport 4+4
    Alright when ever I have to take a turn off the highway or something like that my whole truck skids and suggestions on what is wrong and the tires are brand new so its not that.
  2. Sep 19, 2010 at 4:44 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    too fast...or over imflated tires mabye
  3. Sep 19, 2010 at 6:11 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    haha, slow down on the off ramps! Which tires do you have on your truck, the bridgestones or dunlops?
  4. Sep 19, 2010 at 6:45 AM
    redezman
    redezman Well-Known Member
    Charles
    Raleigh N.C
    2012 4Runner SR5 4x4
    All Factory for now, LOVE it that way
    im fixin to get new michlins ltx m/s2's this week.
    whats a good pressure to run them at?
    2008 double cab
    trd sr5 4x4
    tsb done on leaf springs
    thanks
  5. Sep 19, 2010 at 7:04 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    do the chalk test
  6. Sep 19, 2010 at 7:08 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    slow down...
  7. Sep 19, 2010 at 7:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Are you in 4 wheel drive when this happens?
  8. Sep 19, 2010 at 4:35 PM
    Trd sport 2010
    Nik
    Richmond va
    2010 trd sport 4+4
    i have bridge stones in my truck and also i am not in 4 wheel drive and im speeding.
  9. Sep 19, 2010 at 4:35 PM
    Trd sport 2010
    Nik
    Richmond va
    2010 trd sport 4+4
    im not speeding
  10. Sep 19, 2010 at 5:42 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    What air pressure are you running?
  11. Sep 19, 2010 at 5:54 PM
    AlexXx
    AlexXx Well-Known Member
    Louisiana
    99 taco
    All-Pro 3" Rear kit, Camburg Coilovers, 1" RB BL, 285/75/16's, and rear Lock Right locker Collecting 4wd parts to convert.
    Look at the tire if the wear is not even across the entire thread surface, then air down about 5 psi, do this until it all even. It's easy if you go through gravel to show some color where the terrain is touching or if the nipples are still on there you can tell. I run 30-32 psi in my 33's.
