tires to big?
Discussion in '4 Cylinder' started by yota pride, Oct 9, 2011.
  1. Oct 9, 2011 at 2:29 PM
    yota pride
    yota pride [OP] Member
    rob
    Port Orange
    92 tacoma 38's
    4 inch suspension, 3 inch block, 38s military grade michelins
    i have a 92 Toyota regular cab, its got a 7 inch lift, i have 38's on it, and it shows no sign of struggle, accelerates fine and no bad vibrations, i have the 4 cylinder in it, just wondering if they're to big?
  2. Oct 9, 2011 at 2:31 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Holy shit. Are you geard?
  3. Oct 9, 2011 at 2:32 PM
    TheDuDe06
    TheDuDe06 TEE ARE DEE
    Canada, New-Brunswick
    08 TRD Sport Arctic White
    BDS Suspension 6" Lift with 2.5 Fox Remote Res Coils, Fox 2.0 rear shocks, SPC Adjustable Control Arm, N-Fab Step Bar, WeatherTech Floor Mats, K&N 63-9025 Aircharger Kit, Spidertrax 1,25" Spacers Kit, Fog Light Anytime Mod, ScanGauge II, Magnaflow Muffler, Unichip, Demello Offroad Bumper, SuperWinch 8500Lbs
    ouch 4cylinders with 38"
  4. Oct 9, 2011 at 2:32 PM
    yota pride
    rob
    Port Orange
    92 tacoma 38's
    i have 5:29's in the rear and 410's in the front, but my front drivshaft is out being extended right now.
    haven't gotten around to changing the front yet
  5. Oct 9, 2011 at 2:37 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    match the gears before you blow your diff. up. and I wouldnt see why it would be too big, i know a few guys running 44's on old model 22re's but they are geared to hell.
  6. Oct 9, 2011 at 2:40 PM
    yota pride
    rob
    Port Orange
    92 tacoma 38's
    what are they geared at?
  7. Oct 9, 2011 at 2:43 PM
    98_Mud_bug
    lucedale Ms.
  8. Oct 9, 2011 at 2:44 PM
    98_Mud_bug
    lucedale Ms.
    i think one is runnin 6 somethins but it's sittin on dana 70 front and a dana 60 rear
  9. Oct 9, 2011 at 2:46 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    No they are not.
  10. Oct 9, 2011 at 2:47 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
  11. Oct 9, 2011 at 2:48 PM
    yota pride
    rob
    Port Orange
    92 tacoma 38's
    sorry about no pics, my dad regeared the rear axle for me, what do I need to buy for the regearing of the front axle for 5:29's?
  12. Oct 9, 2011 at 2:53 PM
    98_Mud_bug
    lucedale Ms.
    call east coast gear supply, they can set you up. is it still independent suspension?
  13. Oct 9, 2011 at 2:56 PM
    yota pride
    rob
    Port Orange
    92 tacoma 38's
    straight axle
  14. Oct 9, 2011 at 3:02 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    what kinda axles
  15. Oct 9, 2011 at 3:09 PM
    TRDBandit
    TRDBandit TACOMANATOR
    Justin
    CRAWLORADO
    07 Dbl Cab TRD O.R. Dark Blue
    Afe Stage 2 CAI Tinted windows Many to come
    Dont you need the same gears front and rear? Otherwise your 4 wheel drive is working at different paces. When I broke my axle in my old jeep they put 3.73 in the front and it was supposed to be 4.10. Went wheeling. Popped it in 4x4 and my back wasnt working with the front. My front was spinning at a diff pace causing it to drag the rear. Did not work off road.
  16. Oct 9, 2011 at 3:23 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    correct
  17. Oct 9, 2011 at 3:25 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    He said he doesn't have a front driveshaft and I assume he will change the front before he uses 4wd
  18. Oct 9, 2011 at 3:37 PM
    yota pride
    rob
    Port Orange
    92 tacoma 38's
    yeah i only have the transfer case as far as 4wd goes, the drivshaft is out, and the lever for the 4wd is out also, so i won't be using for a while, is it safe to drive for the time being?
  19. Oct 9, 2011 at 3:39 PM
    98_Mud_bug
    lucedale Ms.
  20. Oct 9, 2011 at 3:48 PM
    yota pride
    rob
    Port Orange
    92 tacoma 38's
    yeah its safe?
