tires to heavy
Discussion in 'Performance and Tuning' started by trp09toc, Jul 20, 2009.
  1. Jul 20, 2009 at 8:39 AM
    trp09toc
    trp09toc [OP] Active Member
    wilkes barre
    09 tacoma double cab SR5
    6in lift volont cold air intake mbrp exhaust 35 toyo m/t
    hey i have a 09 tacoma with 6in procomp lift and toyo open country m/t 35 12.50 E rating and i am putting the second set of wheel bearings on the truck is it possable that the tire is to big if so what tire do think i should put on?
    thanks
    tim
  2. Jul 20, 2009 at 9:52 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I'm going to guess something else is wrong. Cause there are folks that are running 6 inch lifts with no problems.
    SOmewhere else in the drive line there is a vibration or mis-alignment that is cause the wheel bearings to go out. What kind of rims do you have on the truck??
  3. Jul 20, 2009 at 10:09 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    well, the TOYO MTs are insanely heavy tires. They're probably 15lbs heavier than any other tire in that size. With that said, it should be easy to find a tire you like, just lighter. But I also agree that they shouldnt be causing that much of a problem. I know there are plenty of people running them without issue. What wheels are you running? A wheel that sticks out a lot is going to put a bunch more stress on everything, and maybe with the heavy tires thats where your issue is coming from.
  4. Jul 20, 2009 at 10:18 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    or another impressive TSB in the making if wheels are not super wide or have crazy offset.
    Oh, it is 4x4 or prerunner? Not sure if that would have any bearing on the bearings tho, lol.
  5. Jul 20, 2009 at 10:45 AM
    trp09toc
    wilkes barre
    ulta wheels there is 4 3/4 back space on them
    procomp told me that is the mimun backspacing put up to 5 is ok but i reall doint want to but another set of wheels
