Tires too heavy?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Matt777, Jan 13, 2020.
  1. Jan 13, 2020 at 8:40 PM
    Matt777
    Matt777 [OP] Member
    Found a really good deal on some Michelin Agilis lt245/75/r16 tires for my truck. They are e rated. I know this is overkill but they look cool, and ride ok. My question is are they too heavy for stock gearing? According to the specs they weigh 45.3 lbs. I know some of you run 33s and 35s so I think I’m fine. Would just like to hear from someone else running LT e rated in stock size for peace of mind.
  2. Jan 13, 2020 at 8:45 PM
    Shouldnthave
    Shouldnthave Where all the white women at?
    Jay
    TRD-OR Trail Limo
    those are almost identical diameter and weight of the stock tire. You’ll be fine.
    GreyBaldTaco, CrippledHo and whatstcp like this.
  3. Jan 13, 2020 at 8:49 PM
    Shouldnthave
    Jay
    TRD-OR Trail Limo
    Are you sure you got the 245 right? That’s a skinny tire. Now if you’re talking 285/75/16 that’s a whole nother story. You’ll be fine with weight, but you’ll have 33” (ish) tires to deal with.
    kgilly likes this.
  4. Jan 13, 2020 at 8:54 PM
    NM Lance
    NM Lance Well-Known Member
    Personally, I would never use load range E tires on a Tacoma, then again, I have never driven the 3rd gen Tacoma. I would never have put them on my 2nd gen. It is all preference, if you like the "truck" feel, then you will likely be happy with them.
  5. Jan 13, 2020 at 8:58 PM
    Matt777
    Matt777 [OP] Member
    Yes I’m sure they’re 245. They’re stock size just more treaded and e rated. They look good. Was just a little worried about weight, but you all seem to think it’s fine. Thanks again. I’ll stop worrying.
    devkurf and Shouldnthave like this.
  6. Jan 13, 2020 at 9:34 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Beloved here Wildpeaks are almost 50 lbs in this size and the load rating.
    I'm shopping around and thinking to stay with the same size and below 40 lbs if possible.
    245/75/16 wildpeaks at3w 6 ply are $106 on Amazon at the moment
  7. Jan 13, 2020 at 9:53 PM
    Sirnick88
    Sirnick88 Well-Known Member
    Nick
    2011 TX Pro, 6spd MT, boosted
    URD mk3 s/c, Dobinsons snorkel, Ultragauge, Stoptech rotors, TRD ceramic brake pads, softopper, anytime backup camera, anzo black headlights, oh, and vehicle OCD organizers!!!
    I've been using load range E general grabbers at2's for a little over 20k miles. I'm sure my gas mileage took a hit, but I haven't had any issues with the truck, or any noticeable loss in power. E range may be overkill, but I like knowing that I can drive over pretty much anything without getting a puncture.
    JFriday1 and jeff b like this.
  8. Jan 13, 2020 at 9:56 PM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    Load D or C in ridgegrappler or duratrac is the perfect balance of these concerns IMO
    Zoey'sTaco and GreyBaldTaco like this.
  9. Jan 13, 2020 at 11:00 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I go between E-Rated snow tires and C-Rated all terrains in the same outer diameter. There is about 12lbs difference per corner and it is noticeable in acceleration and MPGs.
    Zoey'sTaco and Lt. Dangle like this.
  10. Jan 13, 2020 at 11:30 PM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    I have e-rated KO2s right now. I just got them. I think made a Mistake. Pretty sure I can’t return them.
    Makes a big difference in mpg and power.
    Zoey'sTaco, Colton58D and Lt. Dangle like this.
  11. Jan 14, 2020 at 2:34 AM
    Jasonstacoma
    Jasonstacoma Well-Known Member
    2019 dcsb Barcelona red
    Stock
    You could easily take them off and sell them. Alot of bros love and run those
  12. Jan 14, 2020 at 2:36 AM
    Jasonstacoma
    Stock
    Went to a 265 75 16 SL wildpeak. Mpg dropped a few but power feels the same IMG_20191103_150529_342.jpg
    BalutTaco and Stocklocker like this.
  13. Jan 14, 2020 at 3:31 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    I bought a set of Cooper AT3 4S - 265-75/16's to replace my stock 245's over a year ago and love them, 44 lbs each and no problems with them at all, run great in dry, rain and snow conditions..put them on my factory SR5 wheels..
    devkurf and Tacman19 like this.
  14. Jan 14, 2020 at 4:34 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There are no downsides to an E rated tire. There are downsides to going to larger tires and tires with more aggressive tread patterns. Most of the popular tires in larger sizes and aggressive treads are only available in E rated tires. People buy them and blame the loss of performance and fuel mileage on the heavier E rated tire when the real problem is elsewhere.
    The taller tire effectively changes your axle ratio. A lot depends on the factory axle ratio. Most Tacoma's have 3.73 gears which is already lower than most trucks. Many other trucks come with 3.55, 3.42, 3.31, and some as high as 3.08. Those trucks suffer terribly from bigger tires. Going to a 1" taller tire on most Tacoma's changes your axle ratio to around 3.6 which is still lower than most trucks on the road. Any loss of power is hard to notice. Go to a tire 2-4" taller than factory and you'll need to re-gear, or live with poor performance.
    Wider tires, tires under inflated, and tires with aggressive tread have much greater rolling resistance which will rob power as well as emptying your gas tank sooner. It doesn't matter if they are a 55 lb E rated tire or a 40 lb P rated tire. A narrower tire, with a street tread, or mild All Terrain tread, properly inflated rolls easier, and doesn't hurt fuel mileage. It doesn't matter if it is a 55 lb E rated tire or a 40 lb P rated tire. Stay with an AT tire in 245/75/16, 265/75/16, 265/70/16, or 255/85/16 and you won't have any issues on a Tacoma, even if they are E rated.
    The air pressure recommended on the sticker on the drivers door will no longer apply once you go to E rated tires Neither will the number stamped on the tire. You'll have to experiment, but once you get the air pressure on the tires figured out E rated tires ride just fine. You're not running them on a 3/4 ton truck with a 10,000 lb GVWR so you don't need 50-80 PSI in them.
    I have E rated tires on both my 2007 Tacoma and 2014 F150. They both get exactly the same fuel mileage as before.
    The only downside is initial cost. But over the last 40 years I've damaged too many P rated tires driving on dirt or gravel Forest Service type roads of on farm roads. I've found it is cheaper in the long run to just buy a tougher tire than buying a light duty tire and have to start replacing them before they wear out.
    Little Lion, MJTH, BalutTaco and 3 others like this.
  15. Jan 14, 2020 at 5:53 AM
    Stocklocker
    17TRDORDCSBAT
    You have good points, but it is untruthful to say a heavier tire will not affect MPGs. That’s just plain physics. Rolling mass is an important factor in fuel economy, especially in stop-and-go traffic, and the people, myself included, who noticed a drop from heavier tires in the same size overall are not imagining things.
    Scott4032, C41n, 79CHKCHK and 4 others like this.
  16. Jan 14, 2020 at 6:29 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Say what? The downside is the added unsprung weight and the harsher ride. Those are two pretty big downsides. I realize in theory that 10-15 lbs extra per tire doesn't sound like much and if it were sprung weight, it really doesn't, but unsprung weight and rotational weight are much different. The simplest example is just look what happens when you tack on a 1/4oz to a wheel.
    Scott4032, C41n, Fast1 and 3 others like this.
  17. Jan 14, 2020 at 6:35 AM
    joeydurango
    joeydurango Nightfall Overland
    SW Colorado
    Heavily modified 2015 TRD w/Drifter
    I run E-rated 245/75 R17 Cooper Discoverer ATs. Yes, they are heavier. Yes, MPG and power drop a bit. But I have a camper on my truck and I drive a lot of 4x4 Forest Service roads, and I wouldn't look back on tire choice. Peace of mind is worth a lot.
    Even when I don't have the camper installed, I am still stoked on these tires. Ride quality does suffer a bit, but I don't care about that personally.
    E-rated is unnecessary if you're only ever on pavement or tame gravel - but if you're off road at all, something with a heavier sidewall just makes sense.
    BalutTaco likes this.
  18. Jan 14, 2020 at 6:38 AM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    i have 265 75 16 ko2s e range, and the power drop and mpg was pretty big, ive gotten used to it though.
    i had a hemi ram and when I put bigger tires on it I could feel some powerloss too. just the way things go with bigger heavier tires.
  19. Jan 14, 2020 at 6:41 AM
    DG92071
    DG92071 Well-Known Member
  20. Jan 14, 2020 at 7:36 AM
    navin r
    navin r Well-Known Member
    2017 double cab short bed trd off road 4wd w/ premium pkg.
    I've been running General Grabber At2 245/75-16's load E for about a year and a half. They're about 44 lbs ea., same overall diameter as factory, a little narrower. The factory tires I think were 36 lbs ea., adding 8 lbs to each corner definitely slows down a bit the already underpowered 3rd gen. Load E tires also ride much harder than factory. If you're doing a lot of very difficult off roading load E tires are probably your best bet, if not, I'd stay away from load E tires on a 3rd gen. On the positive side, I haven't had one bit of trouble with the Grabbers.
    Zoey'sTaco and Vlady like this.
