Tires too heavy?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Matt777, Jan 13, 2020.
  1. Jan 18, 2020 at 11:32 AM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    I switched from KO2s e rated to Goodyear ultra terrains today.
    My truck definitely looked cooler with the KO2s.
    but it felt like this to drive without them...
    https://youtu.be/_XYCjVIP_yY
    greyboxer, BalutTaco and fiftyxp like this.
  2. Jan 18, 2020 at 11:41 AM
    CrustyComa
    CrustyComa Well-Known Member
    Michigan
    2020 SR SX TRD Sport love child
    What size KOs and what load rating were you running? How about the ultraterrains?
  3. Jan 18, 2020 at 11:49 AM
    Kamille.bidan
    2017 Blue TRD OR MT
    Both were 265/75/16
    goodyears are SL . KO2s were E-rated.
    KO2s look way cooler and are much more quiet on the road than the Goodyear UT. I just couldn’t deal with the performance downgrade. It wasn’t worth it.
    Ko2
    goodyears
    There are no c-rate KO2s in the size I wanted.
    I wanted cooper AT3 LT/c-rated, but they didn’t pop’ visually like the Goodyear Ultra terrain. I think might just get a second pair of wheels/tires for off-road use. Because getting flats sucks
  4. Jan 18, 2020 at 11:55 AM
    CrustyComa
    Michigan
    Yeah, that is a 13 lb difference per tire, IIRC. I’d imagine that would be noticeable. Did you see Toyo makes the ATII in a load range C 265/75? Weighs 44 or 45 lbs, I can’t remember.
  5. Jan 18, 2020 at 11:56 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    My tires weigh 66lbs each and 88lbs with wheels which is 25lbs heavier per corner than stock. Truck is fine minus the fuel economy.
  6. Jan 18, 2020 at 12:03 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    They both look really nice though. In a few weeks I’m getting the Yokohama x-at in a 265/75/16 I’ll post pics.
  7. Jan 18, 2020 at 12:40 PM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Depending where I’m driving and how I’m driving, I’ve gotten 20.5MPG with 275/70/17 E rated tires and a small lift:notsure:
    gman2431 and 71tattooguy like this.
  8. Jan 18, 2020 at 2:35 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I ended up going with wildpeaks at3w in 245/75/16. Weights 39 lbs +25lbs rim. This is the lightest option I found. Was planning to get skinnies, but there are not many options and weight a ton.
    Dirk Diggler likes this.
  9. Jan 18, 2020 at 2:58 PM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    Pics
  10. Jan 18, 2020 at 3:14 PM
    Vlady
    Issy, WA
    Just received yesterday, need to mount.
    jetfishn and fiftyxp[QUOTED] like this.
  11. Jan 21, 2020 at 8:40 AM
    Kamille.bidan
    2017 Blue TRD OR MT
    Mpg result on my normal commute with Ultraterrains. I normally get 21-22.
    I was getting 18 mpg on the E-rated KO2s.
    Got my power back and my Fuel economy. I may get a second set of E or C rated tires for off roading. the piece of mind would be worth it.
  12. Jan 22, 2020 at 9:10 AM
    ClintS
    ClintS Well-Known Member
    San Diego
    2019 Tacoma TRD Off Road
    Toyota's computer for fuel economy is very inaccurate in most cases. Manually check your miles/gal for to get an accurate result.
    BalutTaco and RED_BEARD 4X4 like this.
  13. Jan 22, 2020 at 9:29 AM
    Kamille.bidan
    2017 Blue TRD OR MT
    According to who? I tracked my mileage for 9 months with hand calculations/excel and my result was pretty much inline with the computer’s results.
  14. Jan 22, 2020 at 9:29 AM
    fiftyxp
    I did fuelly and it was so spot on i just logged out and uninstalled the app. there was no point.
    Scott4032 likes this.
  15. Jan 22, 2020 at 9:31 AM
    #35
    Kamille.bidan
    2017 Blue TRD OR MT
    I reached the same conclusion. With larger tires, I’d understand.
  16. Jan 22, 2020 at 9:40 AM
    #36
    Vlady
    Issy, WA
    I track "fuel economy" for over 2 years. Computer is off by less than 0.5 mpg from manual calculation.
  17. Jan 22, 2020 at 9:57 AM
    #37
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I have general grabber X3s at 63lbs per on my truck. They hit the mileage (22mpgs to 17mpgs), but otherwise are fine.
  18. Jan 22, 2020 at 11:29 AM
    #38
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    I just had a trip where I was running low on fuel, but wanted to see how far I could stretch the tank. I divided the miles driven on the tank (trip meter) by the computer's tank MPG estimate, to get how many gallons I'd used out of 21.1 gal tank. Answer by my math was 20.5 gals consumed. Filled up, put 20.546 gals in.
    That's pretty damn accurate if you ask me.
  19. Jan 25, 2020 at 4:17 PM
    #39
    Vlady
    Issy, WA
    Finally mounted tires. Pumped at 35-36 and the weight is about 65-67 lbs.
    Here is a few pic's of 245/75/16 on trd wheels.
  20. Jan 25, 2020 at 4:24 PM
    #40
    71tattooguy
    Dino
    Petaluma , Ca (707)
    265/75/16 Yokohama X-AT super stoked with these. Mpg’s not worried about it. Definitely no noticeable changes to be freaking out about. It’s a truck
    Junkhead and Jasonstacoma like this.
