Tires VERY close to UCA
Discussion in 'Suspension' started by ryangriffin88, Jun 9, 2017.
  1. Jun 9, 2017 at 11:25 AM
    ryangriffin88
    ryangriffin88 [OP] Well-Known Member
    Brevard, NC
    2009 TRD Sport 4x4 DCSB
    3" Toy-Tec lift, Bilstein 5100 shocks, Banks Monster Exhauat, K&N Cold Air Intake, AFE Throttle Body Spacer, Tinted windows, Black Billet Grille, Black Headlights, 8000K HID Head/Fog Lights, Black Tail Lights, Black LED Third Brake Light, LED license plate lights, LED reverse lights, LED parking lights, LED interior lights, Toyota Bed Mat, 3" Oval Nerf Bars
    I have a 2009 TRD Sport Double Cab w/ 3" Toy-Tec Spacer Lift, 295/55R20 Nitto Trail Grapplers and 20x9 BMF Novakane Wheels (0 offset), the tires do not actually hit the UCA but a re VERY close a few mm's! I know getting some Aftermarket UCA's would be a good choice for helping alleviate this problem, what about some Spidertrax spacers? Or both?
    ChadsPride likes this.
  2. Jun 9, 2017 at 11:25 AM
    1BDTACO
    1BDTACO Well-Known Member
    Joe
    North Dakota
    2017 Tacoma TRD OR
    OME Medium Lift, Fx Pro wheels, Falken at3 285/70/17
    get some hubcentric spacers and you should be fine
  3. Jun 9, 2017 at 11:27 AM
    ryangriffin88
    Brevard, NC
    Would the Spidertrax be good? I believe they are hub-centric.
  4. Jun 9, 2017 at 11:28 AM
    ryangriffin88
    Brevard, NC
    It's not causing a bad ride or anything, I mean the wheel will wander slightly on OE UCA's and lift, but overall rides good, no shimmies or over wheel wobble
  5. Jun 9, 2017 at 12:30 PM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    I believe you need both being at 3" of lift. Front end components will start to fail if you continue driving on the stock UCAs. Spidertrax are hub-centric spacers and would be good. Bora's quality as well.
