Tires w/out a lift?
Discussion in 'Wheels & Tires' started by rdmd35, May 27, 2009.
  1. May 27, 2009 at 5:49 PM
    rdmd35
    rdmd35 [OP] New Member
    R.I.
    I have a 07 4wd Taco, I want to beef up the tires but I need some input from the experience. So, can I put on 265/70/17 or 265/75/17 with out rubbing or any mods to the wheel well? I don't have a lift and don't plan on it. Iam thinking of going with either BFG A/T, Dick Cepek F-C ll, or a Pro Comp. If you have any advice on any of these tires either good or bad, please tell me. Also, I haven't seen much on here with Taco's w/out lifts and tire mods like the way I would like to do, if you have a pic... I'd like to see it. Thk you.
  2. May 27, 2009 at 5:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to Tacoma World!!
    I ran 265/75/16's on my 2000 Tacoma with no issues, and no lift. IMHO, I think the Nitto Terra Grapplers are much better tires than the ones you listed. :)
  3. May 27, 2009 at 5:58 PM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    im not sure what size but i am getting some used tires for free from a friend off his f150 and im going to see if they will fit on my rims/if f150s were 6 lug i would just take his stock rims
  4. May 27, 2009 at 6:00 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
  5. May 27, 2009 at 8:44 PM
    chicken lips
    chicken lips Well-Known Member
    Jose Garcia
    riverside
    07 tacoma
    bone stock for now
    i have a truck like his but mine is a 2wd and im on the same boat as him, im looking for 265/70r17 tires or 265/75r17, does the 70 tire look about the same as stock or should i go with the 75? or do they rub? pics would be nice
  6. May 28, 2009 at 5:24 AM
    muliefever
    muliefever Muliefever
    Tillamook, Oregon
    14' DCSB TRD
    5100's, 887', CB, 265's, FM Deltaflow
    Sport rims= go with a 265/70/17, they will fit and look great
    16" go with 265/75/16 good!
    As for tires, check out the general grabber at2's. They are a very high rated all terrain tire on tire rack, and have a better warranty then most. 3 guys I work with have them, Great! check out www.tiredeals4less.com
  7. May 28, 2009 at 8:37 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    I have 265/70R17's on my 08 4x4 DC.
    No rubbing or clearance problems, but that's the largest tire that will fit without a lift.
    When my wheels are turned, there's only about 3/4" of clearance between the tire and the inner fender skirt.
  8. Oct 17, 2009 at 2:09 PM
    Elliebarley1978
    Elliebarley1978 Well-Known Member
    canada
    weathertech floor liners, wet okole fronts, leer 100xq cap, trd exhaust
    so how is this tire any bigger then the stock? it is not any wider..just a few inches taller?
  9. Oct 18, 2009 at 8:53 AM
    Rocketball
    Scott
    Westminster, MD
    About 1" taller depending on the manufacturer and tread design.
  10. Oct 18, 2009 at 10:50 AM
    kubota man
    kubota man Well-Known Member
    hazard ky
    08 trd off road dc 4x4
    i have 265-75-16 nitto tg and at near full turns mine rubs a little on the flaps but not bad
  11. Oct 18, 2009 at 11:18 AM
    coglark07
    coglark07 Well-Known Member
    Agassiz BC
    Tacoma TRD Sport
    fog lights on without headlights, nfab light bar with piaa 520 fogs
    I just put 265/70/17s on my 07 trd sport with no rubs, I took it off road to test for rub, and there was none at all. I drove over logs, rocks, cross ditches, you name it, with no rub. No more dunlops,,wahoo!!!:D
  12. Feb 9, 2012 at 8:28 PM
    BajaFishTaco
    BajaFishTaco Member
    I know this is an old post but why do you have to run a smaller tire on the 17 in rims? Seems like as long as the outside diameter is the same they should fit. Please help me understand this one. thanks
  13. Feb 9, 2012 at 8:32 PM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    It's not a smaller tire. Tire diameter = (sidewall height x 2) + wheel diameter. Sidewall height = first number (i.e. 265mm) x second number (i.e. 70%).
    265/75R16 has the same width and essentially the same diameter as 265/70R17. The difference is one has more wheel and one has more tire.
  14. Feb 10, 2012 at 7:07 PM
    BajaFishTaco
    BajaFishTaco Member
    Thank you!
  15. Feb 11, 2012 at 9:48 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I have 265/75/16's bfg ko's on American Racing 16x8 Ventura wheels.
    I have heard something very rarely not positive what no damage that I have seen will have to look closer at my front flaps. I will be adding some shim not much room between the rim and caliper made them at work yesterday not on yet need to get some extended thread nuts, studs are none to long.
    The 265/75's were actually cheaper than the 265/70's must be less popular funny the lesser rubber you get the more you pay wish I could run 15" wheels but the brakes are just too big.
  16. Feb 11, 2012 at 10:33 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Good way to compare tire sizes.
    http://www.tacomaworld.com/forum/tirecalc.php
