Tires/Wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dmccurdy7, Jul 31, 2015.
  1. Jul 31, 2015 at 9:29 AM
    dmccurdy7
    dmccurdy7 [OP] Lurker
    Doug
    Caldwell, ID
    2010 6MT ACLB TRD Off Road
    So I'm currently on stock 265/70/R16 tires with my 2010 Tacoma. Would going to 285/75/R16 require a wider wheel? Also, would 33" tires fit without some kind of suspension lift?
    The pic shows with my current tires and stock suspension, also to note I do have the Offroad package.
  2. Aug 1, 2015 at 11:07 AM
    dmccurdy7
    Doug
    Caldwell, ID
    Bumping this. Can anyone help? I'm pretty new and wanna make sure to buy the right tires/wheels along with the right lift.
  3. Aug 1, 2015 at 11:10 AM
    S and J
    S and J Well-Known Member
    Scott
    Las Vegas
    2015 AC SR5 Off Road Package
    As for the wider wheel it depends on which tire you buy. Recommended rim width sizes can be found on the manufacturer's website for each tire. You will have to either get aftermarket wheels with 4.5 inch backspace or wheel spacers otherwise you will rub on the control arms. 33" will rub with a 3" lift so yes they will rub a lot with no lift.
  4. Aug 1, 2015 at 11:12 AM
    dmccurdy7
    Doug
    Caldwell, ID
    So if I buy 33's and put them on the stock wheels with a 3" lift I should expect them to rub?
  5. Aug 1, 2015 at 11:13 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    You probably haven't gotten any responses because this topic has been beaten to death day in and day out. Try using the search feature and you will come up with a wealth of information. But yes you will need a lift to go up to a 285 size tire. You will probably need spacers if you go to a size 285 tire on an OEM rim I believe. But in the end the search feature is your friend.
  6. Aug 1, 2015 at 11:15 AM
    dmccurdy7
    Doug
    Caldwell, ID
    I've searched around just honestly get lost in all the acronyms and specs. Thanks for your help though, I'll keep looking.
  7. Aug 1, 2015 at 11:19 AM
    S and J
    Scott
    Las Vegas
    If you do that they will rub constantly on the control arms...
  8. Aug 1, 2015 at 11:25 AM
    dmccurdy7
    Doug
    Caldwell, ID
  9. Aug 1, 2015 at 2:22 PM
    S and J
    Scott
    Las Vegas
    Correct. They will more than likely rub the entire time. You can get new wheels or get wheel spacers, your choice
  10. Aug 29, 2015 at 10:32 AM
    dmccurdy7
    Doug
    Caldwell, ID
    UPDATE. So I ended up going to Les Schwab and getting a 3 inch lift, 33x10.5x17 Toyo A/T and 17in wheels. Cost with installation was under 2400 and I'm quite pleased with the results. Here are a few before/after pics.
    11813297_10155838145490322_344063916045202072_n.jpg 11226191_10155918347915322_6150548060933379754_n.jpg
    S and J likes this.
