Tires
Discussion in 'Towing' started by flyguy51, Aug 15, 2011.
  1. Aug 15, 2011 at 7:41 PM
    flyguy51
    flyguy51 [OP] Member
    Dave
    Flagstaff, AZ
    2010 DC 4x4 6L SR5
    I've got a question about tire pressure. I will be towing my boat from Arizona to BC in September. The boat trailer has new tires on it and the recommended cold PSI is 65. The spare that I have has a 50 PSI cold rating. If for some reason I do need to use the spare will it cause problems having tires with different pressures? It might be possible that I'd need to tow for a fairly long way until I could get a repair. Thanks for all your help.
    Flyguy
  2. Aug 16, 2011 at 11:45 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    What are the weight ratings on the two different tires? What does the loaded trailer weigh? The ones with the higher weight rating than your spare likely have a different construction with more plies or something. I wouldn't exceed the max pressure on the spare but then I wouldn't want to run the regular tires too low and risk overheating them.
    Personally, I carry a tire plug kit and an air compressor and have had great luck with my tire plugs lasting for many thousands of miles or at least until the tire is worn out. I would probably put the spare on at 50 psi. Just make sure that the tire has enough weight rating for the trailer.
  3. Aug 19, 2011 at 1:25 PM
    2011toy
    2011toy Member
    Jim
    TRD
    Air the tires to their repective max rating and you should be OK even if one is 65 psi and the other is 50 psi. As posted above be sure not to exceed the tires max load capacity.
  4. Aug 20, 2011 at 11:19 PM
    flyguy51
    Dave
    Flagstaff, AZ
    2010 DC 4x4 6L SR5
    I just want to say thanks to both people who responded. I want you to know that I've never been led astray with the suggestions from the members on this site. The folks at Discount Tires couldn't really give me a straight answer about this and they were the ones who sold me the tires. Thanks again.
    Flyguy
  5. Aug 20, 2011 at 11:22 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Going fishing ?
  6. Aug 23, 2011 at 10:38 AM
    flyguy51
    Dave
    Flagstaff, AZ
    2010 DC 4x4 6L SR5
    OZ-T you hit it on the head, I'm getting ready for a fishing trip to BC just after labor day. Never towed my boat this far so I want to make sure that I've got my ducks in order. I'm sure that there won't be any problems but you know how it is when you are doing something for the first time.
    Flyguy
  7. Aug 23, 2011 at 10:39 AM
    OZ-T
    Peter North
    British Columbia
    Where you headed in BC ?
  8. Aug 23, 2011 at 10:45 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    tint, dents, scratches, two blown speakers and trying to pay her off...
    my contribution - flyguy you'll be fine, sounds like you have it all together.
    my derailing - flyguy, your profile says your truck is a 6.0ltr?!!!
    also to oz and OP, whats the best kind of fishing to do up there?
  9. Aug 23, 2011 at 8:00 PM
    OZ-T
    Peter North
    British Columbia
    Salmon
