Tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by smmarine, Dec 8, 2013.
  1. Dec 10, 2013 at 11:23 AM
    Changeling
    Changeling Well-Known Member
    Maryland
    2001 Tacoma TRD SRD V6 X-Cab Limited Edition
    I was in your shoes a few weeks ago when I started looking for tires, I asked the guys over on TacomaForum.com for advise and checked out every tire they told me about and a lot more.
    One guy recommended Cooper AT/3's an all of my research pointed to this being a really great tire. I really like the tread design, especially the open groves around the entire to shuff off water on the highway. It gets high marks/grades across the board, especially for wet conditions witch was why I was tire hunting in the first place.
    My truck had/has Goodyear Wranglers on it and they are terrible in the rain! That's why I am replacing them with the Cooper AT/3's before they kill me. Oh, the GY's have over 3/4 of the tread left, so it isn't low tread wear.
    Check out the posts at TacomaForum.com under 1st generation for yourselves.
    My truck is a 2001 Tacoma 4x4 Limited Edition that I just bought a few weeks ago all stock, no lift.
    The Cooper AT/3's were bought at Discount Warehouse Direct 265/70/16 for $633.00 delivered.
  2. Dec 10, 2013 at 12:02 PM
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    From what I have heard it's pretty normal gas mileage. I have a gas mileage thread and everybody old me it's pretty normal. It has 157000 miles on it. But I do get about 24 highway
  3. Dec 10, 2013 at 12:21 PM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Maybe...but my last one had 198k when it left, and I have 274k on mine now. Perhaps your foot is heavier than mine - I'm usually shifting before 2500rpm. :p
  4. Dec 10, 2013 at 12:30 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I have had very good results out of this AT tire. I am currently running them now. For someone that is MPG conscious this would be a good choice. Id say its probaly one of the best AT tires on the market as far a handling all conditions very well.
  5. Dec 10, 2013 at 2:12 PM
    smmarine
    Melbourne FL
    Looks like my stock rims might be too small. They're the steel 15s, only 6"s wide
  6. Dec 10, 2013 at 3:00 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    I'm pretty sure stock wheels are 15x7 however steelies could be different. if you're running anything above 10.5" wide tires you'll want to get at least 8" wide wheels. you can run tall n skinny tires tho
  7. Dec 10, 2013 at 3:15 PM
    TACO TX
    Kelly
    Denison ,Texas
  8. Dec 10, 2013 at 3:18 PM
    smmarine
    Melbourne FL
    They're the first triangle ones. 15x6. Says on my rim. If I can I'll run 31 or 33x10.50
  9. Dec 16, 2013 at 8:43 PM
    smmarine
    Melbourne FL
    So do you think I would be fine running the duratracs 31x10.5x15 on my 15x6" wheels. It says to mount these on 7-9" rims. Would it be possible to mount them to my rims and would there be any harm if I did?
  10. Dec 17, 2013 at 4:34 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I liked my cooper ST tires. They had huge tread blocks for an all terrain. They are comparable to the BFG At's but the tread blocks are bigger. They do well on dirt and rocks. I went through thick/ deep mud once with them and they did fine, made it through without any issues. Pavement they are good as well, maybe a little louder than street tires but it's expected.
  11. Dec 17, 2013 at 5:04 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    Probably not a good idea. I'm not an expert with tires, but your rims don't even seem to meet the minimum width to qualify for those tires. Just get a smaller tire. Maybe 30x9.5x15?
  12. Dec 18, 2013 at 6:13 AM
    smmarine
    Melbourne FL
    I really wanted as wide a possible. I read that some people do it and you have to run a lower psi to not bubble the middle of the tire and wear it uneven. But other then tire wear it won't cause a problem. A buddy of my ran 35x12.5 on a 8" rim. They called for at least to 9". So mine would basically be the same. 1" lower and his MTs wore great on his truck. Just had to rotate often
  13. Dec 18, 2013 at 8:27 AM
    fast5speed
    Washington D.C.
    But then you think it will be OK because your buddy runs low PSI and rotates them often.
    Some people might think you're contradicting yourself. It might seem like you're talking yourself into a poor decision because you think you'll like it. You said you're worried about MPGs, but you're going to lift it and get bigger and wider tires? You're aware that wider tires = more resistance, and much higher costs, right?
    You talk about how people quickly dismiss the Prerunner as incapable offroad, but you're here because your Prerunner needs any and all help it can get. So what's up?
    Probably not a good idea to circumvent issues just to force something to fit.
  14. Dec 18, 2013 at 8:40 AM
    fast5speed
    Washington D.C.
    Let me share something a bit in the way of existentialism. * the less you have of something, the more significant it is * If you have 100 dollars, giving 1 dollar away is not significant. If you have only 2 dollars, giving 1 dollar away is much more significant.
    Your buddy was only an inch short in the perspective of 8/9. You're an inch short in the perspective of 6/7. This is not the same. You being an inch short is much more significant.
  15. Dec 18, 2013 at 1:25 PM
    #35
    smmarine
    Melbourne FL
    How does that reference work for a tire? Yes a 8/9is bigger but it's still an inch short just like an 6/7 would be. An I'm just trying to get the biggest tires I can. I don't think the 31s are gonna change mpg all that drastically because first gens were sold with a similar size. I think I get such bad mpg cuz I have small tires on a low geared 4.10 rearend. And I'm just getting my prerunner a little better then it is because sometimes I get stuck where I go because it is an open diff. But a 4x4 is not needed
  16. Dec 18, 2013 at 1:42 PM
    #36
    JLee50
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Just get a cheap set of stock 15x7 wheels from Craigslist.
  17. Dec 18, 2013 at 2:49 PM
    #37
    smmarine
    Melbourne FL
    I'm looking for them. Most people are selling a tire combo. I found a set of 5 with 31x10.5s michelins with half tread for 400. It's a good deal, I just don't need the tires and they're by the tires I want
  18. Dec 18, 2013 at 10:21 PM
    #38
    sull625
    sull625 Well-Known Member
    Dave
    Montana
    12 TRDOR DC Spruce Mica
    Show me the mud!
  19. Dec 18, 2013 at 11:48 PM
    #39
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    My vote goes for Goodyear Duratracs! They're a fairly aggressive and very competant tire on various terrains and have pretty decent road manners.
  20. Dec 19, 2013 at 7:22 AM
    #40
    smmarine
    Melbourne FL
    Yeah I'm getting the used 31s off craigslist and am probably gonna slap some duratracs on the back!
