Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Andres1104, Mar 22, 2014.
  1. Mar 22, 2014 at 11:41 PM
    Andres1104
    Andres1104 [OP] Member
    I'm new to this but .. I just want to get some people opinion on some stuff I'm trying to lift my 14 tacoma .. What's a good lift for around 500-600 and will some 33x12.50xr17 fit with the stock rim .. I had some grabbers red lettering in mind .. Thanks so much
  2. Mar 22, 2014 at 11:49 PM
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    Do a little searching in the tire and suspension sections. There's hundreds of threads asking the same questions.
  3. Mar 23, 2014 at 12:04 AM
    Vang Toua Moua
    Vang Toua Moua Well-Known Member
    Vang Bang
    Visalia, CA
    05 Silver Tacoma 2.7, Access cab, 5 lug
    Custom front bumper and rock sliders, glasspack muffler, shorten exhuast, abs killswitch, roof light bar, rear e locker.
    Front bilstein shocks and add a leaf. If your stock rims are 17s, they should fit.
  4. Mar 23, 2014 at 12:23 AM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    You didn't post nearly enough info. What do you plan on doing with the truck? What model of truck do you have?
  5. Mar 23, 2014 at 4:33 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    X2..I'm pretty sure that tire size will be not only difficult to find with limited selections, but its too wide for stock rims. On top of that, you will need 1.25" wheel spacers ,some trimming and a 3 in lift. Look into 285/70/17. Those red grabbers look cool but there are better all around tires and cheaper than those. (Duratracs)
  6. Mar 23, 2014 at 4:48 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    You just can't drop on question like that and think you're going to get an answer. This has been asked thousand times, and the answer is always the same. Do some research. This site has hundreds or writeups on any combonation of lift kit; shocks, coils, leafs, and tires.
    Do some reading, and come back with a more inteligent thought out question.
    Frank
  7. Mar 24, 2014 at 11:47 PM
    Spencer
    Spencer Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    USE
    THE
    SEARCH
    or just browse around.
    But to directly answer your question with the greatest advice nobody here seemed to give me:
    Get your ass out to some meets!
    Go out and meet us in person and see our rigs before you get the idea in your head you gotta build it up before you can enjoy it.
    Come see some long travel guys, give em some beer and get a ride in an LT truck.
    Check out the mid travel guys, (like me)
    Take a ride & see how it handles. Then check out the block lift guys and you'll find out real quick what the best answer to this question is.
    If you want 285/75's, understand you're about to cut and weld your frame. Check out my build page and for the love of god why would you insult a 30,000$ truck with a "lift kit" that costs less than two of your payments.
