Tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by Merle16, Nov 4, 2016.
  1. Nov 4, 2016 at 4:37 PM
    Merle16
    Merle16 [OP] New Member
    1998 Prerunner 2.7
    Just bought a set of 18" 35s for my son's 1998 prerunner. Will they clear? He has 2" spacers if that helps?????
  2. Nov 4, 2016 at 5:13 PM
    SAB_0010
    SAB_0010 Well-Known Member
    Seth
    1996 Tacoma 3.4l 5-speed
    Not with only two inches of extra clearance. Trade them for some 32s
  3. Nov 4, 2016 at 5:17 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    If you buy him a sawsall too they'll fit.
  4. Nov 4, 2016 at 6:02 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Tubbing the wheel wells is required and also that would be extreme strain on your stock diff gears and 4 cyl motor. Depending on width you will also hit the uca's.
  5. Nov 4, 2016 at 7:36 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Research! Research! Research!
  6. Nov 5, 2016 at 6:08 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    ^^^this!!^^^
    Without a 6" drop bracket lift running those things will require a full 3" lift and a good bit of extra work! Tubbing and cutting the front corner of the cab off and welding in a new piece of sheet that you've formed will be needed. That's a big tire to run and like mentioned already, with that lil 4 banger you're gunna need a gear swap unless the truck being an absolute dog and not being able to get out of its own way (literally) is okay with ya?? A gear swap would be a necessity if it were mine. Honestly I'd say it would be a better idea to ditch the 35's and go smaller. I know you dont wanna hear that since you already have the big meats but the time and potential cost if you cant do the labor for gears and fab work stuff just dosent make it worth it....and to boot it dosent have 4 wheel drive.
