Tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TaCoTuEsDaY16, May 28, 2017.
  1. May 28, 2017 at 7:26 AM
    TaCoTuEsDaY16
    TaCoTuEsDaY16 [OP] Well-Known Member
    Adam
    Louisiana
    2018 Tacoma TRD off-road 4x4 DCSB
    what size tires can I run with a 2.5" in. lift the front and 1.5" in. lift the back? I'm running 265/70R16 right now.
  2. May 28, 2017 at 7:43 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    35's would look sweet
  3. May 28, 2017 at 8:44 AM
    TaCoTuEsDaY16
    Adam
    Louisiana
    Idk if I can run 35's on that lift I don't want it to rub in anyway I was looking at some 285/75r16 ko2's
  4. May 28, 2017 at 8:52 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    See the links in my Sig on tire size there are two and will answer your questions.
  5. May 28, 2017 at 9:28 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    You could run 35" but would have to trim. 33" is the most common but you will rub even with a quite a bit of trimming unless you run skinnies.
  6. May 28, 2017 at 9:32 AM
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    Finally a new question
    The largest size that can fit without trimming a cmc and a pinch weld being hammered in is 265/75/16
    Edit: if you're into skinny tires 255/85/16 should fit fine
