Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gregory28, Jun 24, 2017.
  1. Jun 24, 2017 at 7:48 PM
    Gregory28
    Gregory28 [OP] Member
    Greg
    07 reg cab Toyota Tacoma
    Right now 3 inch lift 3 inch body lift but I am going to put 6 inch lift on later
    ok so I have a 07 Tacoma with a 2.7. I have a 3 inch body lift on it now and putting on a 6 inch lift on in the next two days. I have 18 inch rims on my truck what is the biggest tires I can run on it with 18s
  2. Jun 24, 2017 at 10:21 PM
    Pigpen
    Dan
    Northwest Montana
    45s
    desertrunner24 and FawkQ like this.
