tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by demogorgon217, Aug 14, 2020.
  1. Aug 14, 2020 at 6:55 PM
    demogorgon217
    demogorgon217 [OP] Well-Known Member
    gordon
    Louisiana
    Gloria
    auto zone valve stem covers
    can anyone tell me what the biggest tire size is that i can get without having to do a lift? will be putting on 16”x8” wheels with 2” spacers
  2. Aug 14, 2020 at 6:58 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  3. Aug 14, 2020 at 7:00 PM
    demogorgon217
    gordon
    Louisiana
    Gloria
    hell yes thanks bud
  4. Aug 14, 2020 at 7:02 PM
    demogorgon217
    gordon
    Louisiana
    Gloria
    wait tho is tgat for 2nd gens or 3rds? google is showing me only pics of 3rd gens with no lift and these specs
  5. Aug 14, 2020 at 7:05 PM
    Plain Jane Taco
    USA
    I run snow tires on stock steelies in that size. I'm a 2nd gen.
  6. Aug 14, 2020 at 7:06 PM
    demogorgon217
    gordon
    Louisiana
    Gloria
    alright then you’ve cleared it up for me. thank you!
  7. Aug 15, 2020 at 5:39 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    265/75/16 will rub on 16x8 rims stock are 16x7 tried and had to lift.
    oops reread and see spacers that I cant answer about sorry.
    demogorgon217[OP] likes this.
  8. Aug 15, 2020 at 5:52 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  9. Aug 15, 2020 at 7:53 AM
    Pigpen
    Dan
    Northwest Montana
    With 2" spacer, you're going to rub like crazy when you try to turn. You're truck will have the turning radius of a school bus.
    Not hating, just trying to help you out.
  10. Aug 15, 2020 at 9:33 AM
    demogorgon217
    gordon
    Louisiana
    Gloria
    damn so might as well just get 35s and go for that lift anyway
  11. Aug 15, 2020 at 11:28 AM
    Pigpen
    Dan
    Northwest Montana
    You'll have to cut off a bunch of your truck to run 35s. The simplest thing to do is stick with stock wheels and 265/75/16 or 265/70/17 if you don't want to lift. Simple 2-3" lift, use stock wheels and 255/85/16 or 255/80/17 tires.
    Of course, if you aren't afraid of chopping your fenders, hammering the pinch weld and resealing the wheel wells, and chopping the cab mount - I say go for 35s!
    I chose the 255 route with a 3" lift - and my CV boots are eating themselves. I already had to replace one axle.
