Tires!!
Discussion in 'Wheels & Tires' started by Juice333, Sep 14, 2020.
  1. Sep 14, 2020 at 10:31 AM
    Juice333
    Juice333 [OP] Member
    OJ
    17 Trd OR SB
    So I’ve done some searching here but I haven’t found my answer so I gotta ask even though it must’ve been covered somewhere here. 17 OR. I have a 2” spacer in front, 1” block in the rear. I wanted to put 1.25” spidertrax wheel spacers on stock wheels. I also want to put 285/75/16 faulkens on. With the wheel spacers will I still have some rub? I do light off-roading, heavy snow driving.
  2. Sep 16, 2020 at 4:15 PM
    Juice333
    OJ
    17 Trd OR SB
    Ok good talk ( as I high 5 myself )
  3. Sep 16, 2020 at 4:24 PM
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    First, the lift doesn't really help much with rubbing unless you always keep your steering wheel straight when driving over speed bumps, off road, etc. It's all about the offset.
    The ideal offset for the least amount of rubbing with 285s is between +10 and 0. Even with this you would have minor plastic trimming.
    Your setup (assuming stock wheels) is +25 offset pushed out 1.25 inch (or 32 mm) for a total offset of -7. You will definitely have some plastic trimming to do and also most likely a cab mount chop.
  4. Sep 16, 2020 at 4:36 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
  5. Sep 17, 2020 at 10:52 AM
    Juice333
    OJ
    17 Trd OR SB
    Ok thanks David, I see sooooo many posts about it some people say oh no prob, I did it, got 20k on it no rub at all. I really wanted the 285’s but I definitely do not want to cut it up. Thanks again
  6. Sep 17, 2020 at 12:28 PM
    Juice333
    OJ
    17 Trd OR SB
    So if i went with a 1" spacer that would bring me to about a zero offset. Then I'd be doing some plastic trimming? Is that correct?
    seniorredwood likes this.
  7. Sep 17, 2020 at 2:29 PM
    rocky_mountain_dave
    David
    Disclaimer, I do not have 285s, but I have read tons and tons about different configurations. My understanding is yes, you can probably get away with just plastic trimming with a 1" spacer and a good alignment (caster set to 3).
