Tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Massey01, Nov 21, 2022.
  1. Nov 21, 2022 at 6:58 PM
    Massey01
    Massey01 [OP] New Member
    Gary
    2022 sr5 tacoma v6
    It seems a 245/75/16 is very close in size to a 265/70/16 tire. 265/70/16 is wider, but the height is basically the same as is the sidewall. The wider look might look cool.
  2. Nov 21, 2022 at 7:06 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Go taller -255/85/16
    Massey01[QUOTED][OP] likes this.
  3. Nov 21, 2022 at 7:10 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Go lighter 265-75-16, no need for a heavy E load 10ply tire.
  4. Nov 21, 2022 at 7:16 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    265/70/16's came from the factory on mine. I assume they are still an option. I upsized slightly to 265/75/16 years ago. They are about 1" taller than stock and the same width as 265/70/16's and only about 3/4" wider than 245/75/16. I don't see any downsides. They are not enough bigger to hurt anything, and they are a more common size that cost less.
    If you do a lot of off-road driving, or even spend a lot of time on unimproved dirt roads the tougher E rated tires are a viable option. They do weigh more, and do ride a little harsher, but the difference isn't a deal killer if you NEED a tougher tire. The biggest downside is that they are much more expensive and if you don't need them, why pay for them.
    Massey01[OP] likes this.
  5. Nov 21, 2022 at 7:17 PM
    Vlady
    Issy, WA
    Yeah, hopefully some day these will come in 4-6 ply version
