TIS Tacoma Techstream to Update 2nd Gen ECU
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMan46', Jul 3, 2023.
  1. Jul 3, 2023 at 7:14 PM
    TacoMan46'
    TacoMan46' [OP] New Member
    Michael
    09' AC. Tacoma 4x4 5spd Manny 2.7 2trfe
    HX35 Turbo w .83 TurboLabs Turbine Housing, FMIC Full 3" Exhaust System 300HP. Clutch Pkg. Bilstein 5100's 2" Front Level Up AEM Water Meth & AFR Water Temp. Oil Pressure Gages
    Gooday All..
    Looking for some assistance w Techstream..
    At this point.. I'm all the way In! Having put 8000kms on my Turbo Taco 2trfe'.. Still on Stock ECU & Injectors' .. per Auzie Rules' nd ShedKing's Stock 3RZ Turbo Inspiration.. a couple years back..
    I do have a vFTuner Kit' ready t Go' but..
    My Stock ECU' misses the Mark' w/in the vFTuner Database as Listed by (1) Digit .. As mine was apparently Updated by a TSB' there by changing th number .. Argh'
    Now have to gain access to TIS Techstream in order to Update' then I'll be on my way .. Do some Data Loging'.. Pull some Timing' Add Fuel' Put a Bigger Spring in th Gate' etc. via vFTuner..
    Question Is.. Which Version of Techstream do I need for my Gen2 Taco 4 Banger?
    The more I research the more questions I seem to have..
    I jus wanna Update' my ECU' & move On!.. Help'..
    Any help here wood be mega appreciated..
    Cheers All
    Michael
  2. Jul 3, 2023 at 8:23 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    TacoMan.46' likes this.
  3. Jul 3, 2023 at 10:40 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Any version will work, at least through V17. V14 worked until the 2018s were released, I believe.
    TnShooter likes this.
  4. Jul 3, 2023 at 10:40 PM
    TnShooter
    Deogee
    STOCK
    Thanks.
    I figured you would know:thumbsup:
    tonered[QUOTED] likes this.
  5. Jul 3, 2023 at 10:40 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Cheers!
    TnShooter[QUOTED] likes this.
