TIS Updated with 2016 Tacoma information
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff Lange, Aug 18, 2015.
  1. Aug 18, 2015 at 9:49 AM
    Jeff Lange
    Jeff Lange [OP] Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Just taking a quick look through it, some interesting things.
    Dual VVT-i added to 2TR-FE.
    Manual transmissions are RC62F (changed from RA60) for 2GR-FKS and R156F (changed from R155/R155F) for 2TR-FE (Triple cone syncro for 1st, most ratios changed, GL-3 or GL-4 instead of GL-4 and GL-5 for gear oil).
    The 2GR-FKS seems very similar to other D4-S 2GR engines like the 2GR-FSE, of course with the addition of VVT-iW to the intake camshaft to allow for Atkinson Cycle operation. It uses high power triple-electrode long-reach iridium spark plugs, which are good for 60,000 miles and are probably expensive. All A/T models get the 130A alternator, M/T get 100A or 130A with towing package. DI + Port injection appears to only be used at lower engine RPM's, while DI is used exclusively at higher loads and RPM's.
    The 3.5L specs of 278hp and 265ft-lbs appear to be done on 87 (91 RON) octane.
    The 6-speed auto is the AC60E and AC60F, which aren't used in any other current Toyota models in North America, I think.
    I'll look through things and post cool bits, but if you want to check it out, it's on TIS.
    Jeff
  2. Aug 18, 2015 at 10:14 AM
    Jeff Lange
    Calgary, Canada
    There are now 8.0" and 8.8" rear differentials, depending on which model/options you have selected. All locking rear diffs are 8.8".
    Front lower control arms are stronger and the bushings/bolts are larger.
    Only the off-road package gets the upgraded shocks, previously the TRD Sport did as well, I believe.
    The TPMS system now shows pressures for each wheel, based on distance to the receiver, so you can still rotate the tires and the pressures will show on the correct wheel.
  3. Aug 18, 2015 at 10:20 AM
    AdventureKid
    AdventureKid Let's Go Places
    Jake
    Oceanside, CA
    17' DCSB TRD OR 4x4 6MT
    Camper Shell
    Question... If I am buying the 16' TRD Sport (since I want an AC Manual) will that 8.0" rear be inferior to the 8.8" on the TRD? Eventually I'll probably put a air locker in there...
  4. Aug 18, 2015 at 10:20 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    On SR5 and above.
  5. Aug 18, 2015 at 10:28 AM
    cgalloni
    cgalloni Well-Known Member
    That sucks if the optimum HP is not achieved with regular gas!
  6. Aug 18, 2015 at 10:31 AM
    Jeff Lange
    Calgary, Canada
    Owner's manual states 87 or higher octane required. NCF shows 91 or higher, but doesn't specify the method, owner's manual is more clear, 87 R+M/2, 91 RON.
    They show in detail how they've modified the frame and cab structure for increased rigidity, lots of extra bracing it looks like (welded on and bolted on).
    Toyota has added a lot of foam, larger weatherstrips, etc., to reduce noise. Even inside the doors. The also made the windshield and back glass thicker.
  7. Aug 18, 2015 at 10:39 AM
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    I knew I had read something about this earlier. From the Toyota News release:
    "...Tacoma TRD Sport models are equipped with sport-tuned shocks. TRD Off-Road models include an off-road tuned suspension equipped with Bilstein® shocks."
    So the Sport gets special shocks, just not by Bilstein?
  8. Aug 18, 2015 at 10:44 AM
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    @Jeff Lange - thanks for the excellent data. Always appreciate constructive, useful posts around here.
    I wonder how much extra power this 2GR variant could output using premium if it was tuned as such. Would be nice to have the option (e.g, I am towing through the mountains today and need all my horsies for the afternoon).
    AdventureKid likes this.
  9. Aug 18, 2015 at 10:48 AM
    Jeff Lange
    Calgary, Canada
    Sounds like it, yeah.
    Probably similar to the 311hp / 280ft-lbs the 2GR-FKS gets in the GS350.
    Jeff
  10. Aug 18, 2015 at 10:51 AM
    AdventureKid
    Jake
    Oceanside, CA
    Camper Shell
    @Rock Lobster ... Very true. Time will tell. Question for you... I ordered the 16' already, but my hang up is the Rear Locker(TRD OR) vs Non rear locker(TRD Sport). Toyota said they revised it.. I would really like the Rear locker for this situations but the don't make the AC Manual TRD OR only in the TRD Sport... That 6' bed is what I am really hanging up on, along with rear locker... Can anyone help me figure this out
  11. Aug 18, 2015 at 10:52 AM
    jonnyozero3
    Dry places
    '99 TRD OR V6 M/T
    Good point. Would be an interesting marketing-driven move by Toyota to do that....offer a Premium Gas map. Then they could advertise best-in-class power. Tricky, but still valid.
  12. Aug 18, 2015 at 10:59 AM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    So the engine will use Direct Injection AND Port Injection AT THE SAME TIME at lower RPMs? So gas will be coming out of the port injectors and the head injectors AT THE SAME TIME?
  13. Aug 18, 2015 at 11:04 AM
    Jeff Lange
    Calgary, Canada
    Yes, this is done in all D-4S systems, though when both are used varies.
    Jeff
  14. Aug 18, 2015 at 11:10 AM
    Z50king
    Eric
    Southern California
    Stock and loving it
    Thank you very much for your reply. No one ever had an answer to this when I previously asked
  15. Aug 18, 2015 at 11:11 AM
    Jeff Lange
    Calgary, Canada
    A second detent has been added to the door check to stop the door in a second position when opening it.
    HFO 1234yf (R1234yf) is used for the A/C system. I believe they have moved the entire A/C system away from the Delco type to a Denso system. Should use ND-12 oil.
    It looks like they've added a PTO quick heater as well. (An electric heater that warms the cabin until the engine is up to temperature).
  16. Aug 18, 2015 at 12:25 PM
    jonnyozero3
    Dry places
    '99 TRD OR V6 M/T
    Oh thank god. Good heat without waiting is amazing when you have it.
  17. Aug 18, 2015 at 12:37 PM
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    oh can't wait.
  18. Aug 18, 2015 at 1:13 PM
    border411
    border411 Well-Known Member
    Jeff....you are awesome!
  19. Aug 18, 2015 at 2:40 PM
    thepinktaco
    thepinktaco Well-Known Member
    Cody
    Orange, MA
    95 SAS Tacoma, 99 4runner, 16 Tacoma.
    Ive been checking TIS every day Im on there, even checked this morning waiting for NCF to show up
    . Must have changed it right after I was on there.
  20. Aug 18, 2015 at 3:22 PM
    Jeff Lange
    Calgary, Canada
    =JSG= likes this.
