Title change...it lives...it lives!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kidthatsirish, Jul 19, 2024.
  1. Jul 19, 2024 at 2:20 PM
    kidthatsirish
    kidthatsirish [OP] Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Truck drove fine....
    Went to start it in Parking lot.
    Key on, heard a click and everything died.....no dome light no nothing.
    Good battery.
    A few minutes later tried again, power came back on. Tried to start, lost all power again, not even a dome light. Heard a click near or in fuse box. Again no power.
    Any ideas?
    Ok....so it seems like there is some kind of circuit breaker that reset itself after a while.
    Key in, seemed normal, went to start, again, lost all electrical power including dash lights, and some light.
    Tried a jump start. Nothing. I'm trying to get back to my house to get my moving truck packed. I'm supposed to drive from Omaha Nebraska to Maryland tomorrow.
  2. Jul 19, 2024 at 2:42 PM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    Clean post and terminals
    GilbertOz, ridefreak and Daulll like this.
  3. Jul 19, 2024 at 2:43 PM
    kidthatsirish
    Done, didn't help, the terminals were clean and tight.
  4. Jul 19, 2024 at 2:51 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Ground off battery terminal to chassis good?
    First time it's had issues like this recently?
  5. Jul 19, 2024 at 2:51 PM
    kidthatsirish
    Yes to both questions
  6. Jul 19, 2024 at 2:57 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
  7. Jul 19, 2024 at 3:01 PM
    SethM
    Seth
    Los Angeles ca
    Fuel pump relay
  8. Jul 19, 2024 at 3:02 PM
    kidthatsirish
    This would cause all electrical to kick off?
    Which one is the fuel pump relay?
    I assume there may be another relay I can swap it with? Maybe AC?
  9. Jul 19, 2024 at 3:32 PM
    SethM
    Seth
    Los Angeles ca
    I didn't think about the electrical, have no clue.
    drizzoh likes this.
  10. Jul 19, 2024 at 3:41 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Try another battery, maybe.
  11. Jul 19, 2024 at 3:43 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    That's why I didn't ask in my previous question. That was my first thought as well but wouldn't explain the electrical.
    If there was a fuse box click it could be a relay that died, but not sure which one would cause the interior lights and everything to die. Seen that with the Room/Cabin fuse, but that won't prevent the vehicle from starting.
    Did it fire up at all with the new battery or could both batteries bad? And you're 100% sure in the panic that the new battery got installed and not the old one again?
  12. Jul 19, 2024 at 3:44 PM
    kidthatsirish
    Battery is good, also tried a jump start
    The truck is not trying to crank.
    As soon as I turn the key to start it's a complete loss of all electrical power. Some sort of fuse or relay pops, and then it takes a while for it to reset
  13. Jul 19, 2024 at 3:46 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    F. I'm out of ideas for a quick fix without seeing it at this point.
  14. Jul 19, 2024 at 3:47 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    So, how old is the battery?
    henryp likes this.
  15. Jul 19, 2024 at 3:53 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    You may think battery is ok but it still sounds like the battery is the issue. When jumping DO NOT connect negative side of cable to the battery, connect to a solid grounding point on engine.
  16. Jul 19, 2024 at 3:55 PM
    JCruiser
    JCruiser Well-Known Member
    Master Chief (E-9) USN (Ret)
    Georgia
    '23 Tacoma SR5 4WD 4D "Ice Cap" w/ XP Package
    Upcoming...... Pro grille and driving lights
    Check your your larger fuses both under the hood and under the dash. The "click" may have been a fuse getting blown..... or check your starter relay.
  17. Jul 19, 2024 at 3:58 PM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    Check all of the grounding cables. Not just that they're fastened/bolted but give them a tug to make sure they're not corroded inside the connectors.
    Beyond that my bet would be an internal fault in the battery that only occurs under load.
  18. Jul 19, 2024 at 4:01 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    This sounds like a main power or ground issue, do you have a meter or test light with you?
    TnShooter likes this.
  19. Jul 19, 2024 at 4:07 PM
    John43
    John43 Well-Known Member
    Dallas
    07 PreRunner
    Alternator.
    Steves104x4 likes this.
  20. Jul 19, 2024 at 4:08 PM
    kidthatsirish
    Truck has started several times over the day.....strong start every time, voltage was good.
    Tried a jump start with no help.
    I'm going to wait for whatever thing is popping to cool down and hopefully reset, try and pull back the truck and roll start it by popping it into second gear.
