Title change...it lives...it lives!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kidthatsirish, Jul 19, 2024.
  1. Jul 19, 2024 at 11:11 PM
    #41
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    TnShooter, Jimmyh and usmc2msu like this.
  2. Jul 20, 2024 at 8:38 PM
    #42
    kidthatsirish
    kidthatsirish [OP] Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I'm not sure honestly. I have not had any chance to do any trouble shooting. Earlier today I put the key in the ignition and put it in the on position. Pushed it and pop started the truck since it doesn't seem to like me trying to use the starter.
    It started, and without touching any switches drove it right onto the trailer and chained/strapped it down. I will have to continue troubleshooting post move.
    Jimmyh likes this.
  3. Jul 21, 2024 at 12:28 PM
    #43
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like a ground issue. Something is back-feeding the oil light.
    TnShooter likes this.
  4. Jul 21, 2024 at 12:30 PM
    #44
    Jimmyh
    SC
    2012 Prerunner SR5
    Disconnect them on both the positive and negative connections. Just removing the fuses may not do what you want.
  5. Jul 21, 2024 at 9:54 PM
    #45
    kidthatsirish
    Yeah I will have to see what I can do once I have the chance.
    Drove 800 miles today as I am moving. Stopping for the night in Dayton Ohio.
    Tomorrow night I'll be in Maryland.
    Jimmyh[QUOTED] likes this.
  6. Jul 21, 2024 at 9:56 PM
    #46
    kidthatsirish
    But shouldn't the oil light always be illuminated when the key is in the on position and the engine isn't cranking?
    Once I remove the key from the ignition, the light goes out
  7. Jul 21, 2024 at 10:32 PM
    #47
    Jimmyh
    SC
    2012 Prerunner SR5
    Correct, but it should be 12 VDC on the positive side and 0 VDC on the ground side.
    If there is a back feeding issue on the ground side where there is 12 VDC on the positive side and say 4 VDC back feeding into the ground then you will only have 8 VDC to do any work, which would give you a dim light and everything else would be under powered also.
    I hope this makes sense to you.
    Torspd likes this.
  8. Jul 22, 2024 at 6:03 AM
    #48
    kidthatsirish
    I see what you are talking about now.
    Yeah I will have to figure that one out.
  9. Jul 22, 2024 at 9:13 AM
    #49
    Moto521
    Moto521 Well-Known Member
    2006 Tacoma DCSB TRD OR
    I had the exact same initial symptoms happen on my first gen. Tundra.
    Never had an issue, no slow crank or any problem before hand. Stop at my storage unit for twenty minutes and then nothing. Tried a jump, no go. Went home and got some tools/ dvom and battery checked out but no power past that. Pulled batt. terms, all good.
    Noticed the ground cable was swollen about an inch before the end of the cable. Cut it open and yeah. totally full of battery acid corrosion.
    I think the previous owner had a leaking battery and it wicked down the cable.
    Anyway, I cut out about two inches to get to fresh copper, tossed on a temp. term. and boom. Everything back to normal.
    Still baffles me how it didn't show any advanced symptoms.
    kidthatsirish[OP] likes this.
  10. Jul 22, 2024 at 2:00 PM
    #50
    kidthatsirish
    Yeah the ground cable at the battery is good.
    Right now I'm sitting on the side of the road (again) waiting for roadside assistance to show up with a trailer tire for the U-Haul trailer behind my expedition as they don't provide spare trailer tires with them when you rent them.
  11. Jul 22, 2024 at 9:57 PM
    #51
    kidthatsirish
    Definitely gonna look at this....I know I have fresh copper on the battery ground as I just redid that one a few weeks ago.
    Gonna have to check the positive as well.
  12. Jul 23, 2024 at 6:06 AM
    #52
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    Not just at the terminal, check the chassis and engine grounding too. Last time I had this issue it was on a Civic and it was the chassis ground.
  13. Jul 23, 2024 at 6:55 AM
    #53
    kidthatsirish
    Yeah I plan to as soon as I get this moving truck unpacked and trailers and what not returned. I pulled into the hotel near my new place about 1am.
    Hopefully its just a loose ground from when I repaired my truck. That would be ideal.
  14. Jul 23, 2024 at 6:14 PM
    #54
    kidthatsirish
    So I off loaded the truck from the trailer again today.
    Push started it so I could drive it to the parking spot.
    Once I got it where it could sit for a bit if needed. I turned the headlights on again and immediately the engine died again.
    Interesting symptom.
    Additionally I noticed that my horn has stopped working.
    I'll start working on it like on Monday when I get a chance.
    BKinzey, usmc2msu and TnShooter like this.
  15. Aug 3, 2024 at 7:51 AM
    #55
    kidthatsirish
    Well, I got a little bit of an opportunity to troubleshoot.
    The following readings are with the key removed from the ignition:
    Battery Terminal to battery terminal is 12.54 volts.
    Positive battery terminal to all grounds by front passenger headlight, near the smog pump, and on the driver side firewall measured 12.54 volts
    Voltage from positive battery terminal to the post inside the fuse box is 0.00 volts
    Voltage from the post inside the fuse box to the negative battery terminal was 12.54 volts
    Trying to get to the starter but because of where I live it's really hard to get under the truck right now.
  16. Aug 3, 2024 at 8:57 AM
    #56
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Those readings look good so far.
  17. Aug 3, 2024 at 9:07 AM
    #57
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Really would like to have the key on when doing voltage drop checks, we want the circuit "loaded"
  18. Aug 3, 2024 at 9:33 AM
    #58
    TnShooter
    Deogee
    STOCK
    Just throwing this out there.
    In your first post. You said, "the dome light wont work".
    If you turn it ON, not door, but on at the switch. Then test the dome fuse for power.
    If the fuse has power, we know we are chasing a ground issue.
    If it has no power, we know we are looking at a power issue.
    As of now, I sticking to a ground issue. But that's guess. And should only be used as a "guess" to where to start looking.
    usmc2msu likes this.
  19. Aug 3, 2024 at 9:42 AM
    #59
    kidthatsirish
    I'll try that out. My only concern of course is that it's somewhat intermittent. Sometimes the some.light and dash comes on just fine. I try and crank, all lights go out....I have to wait what seems like 15-20 minutes before it seems to "reset" for lack of a better term to try a new step in troubleshooting.
    Really slows things down.
  20. Aug 3, 2024 at 9:50 AM
    #60
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Wallet loss happens on this site.
    I'm not hopeful but just to throw an idea, your no crank/lights sounds like a Camaro I had long ago. Positive at the starter came loose and was corroded.
