TJM locker vs ARB locker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BR Pipke, Jan 5, 2017.
  1. Jan 5, 2017 at 3:08 AM
    BR Pipke
    BR Pipke [OP] Well-Known Member
    Drayton Valley Canada
    11 TRD short box 6speed std with 3" lift bilstein 5100 struts pro comp UCA AFE air cleaner and throttle spacer ultra rims 265-70/18 dual exhaust
    Has any been using TJM locker? How does the TJM locker stack up against a ARB locker? The TJM is an Australian made where the ARB is US made
  2. Feb 21, 2017 at 2:27 PM
    azgunrunner
    azgunrunner A guy that knows a guy, that knows a guy...
    George
    Arizona
    06 DCLB Sport
    ADS 2.5, Dakar leaf springs KMF sliders CBI Ditch light mounts, DD SS3 pods Bumpers pending OBA pending
    i bought a TJM air locker, just haven't gotten around to installing it yet.
  3. Feb 22, 2017 at 8:20 AM
    tgear.shead
    tgear.shead Well-Known Member
    Where do you see that ARB is USA made?
    https://www.arb.com.au/about/
    Personally, this would be *my* choice for a locker;
    https://www.harrop.com.au/shop/4x4-performance/elocker/elocker-toyota-tacoma-rear-shimmed
    (althought I'm not sure if that is for a 2005+, or 2004-)
    ... they also have listings for both FRONT and REAR lockers for 4-runner and fj. Probably some of those would fit.
    No stupid air compressor. Just give it electric and be done with it.
    Edit:
    http://yotalockers.com/pages/toyota-tacoma-1995-to-2015
    Yep, there are two part numbers available for front, based on the differential ratio. One part number for rear. Definitely compatible with 2005+.
  4. Feb 22, 2017 at 8:34 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
  5. Feb 22, 2017 at 9:06 AM
    BR Pipke
    I'm not sure if air will work in weather we get cold warm then cold. Am concerned about the lines freezing up and then when I need the locker it doesn't work. Any one have any problems with the lines freezing?
  6. Feb 22, 2017 at 9:08 AM
    tgear.shead
    Right, why do you think that I pointed out an ELECTRIC locker for you?
    No stupid air lines and compressors to cause you problems.
  7. Feb 22, 2017 at 3:29 PM
    BR Pipke
    That's what I'm thinking.
  8. Feb 22, 2017 at 8:06 PM
    Scribbles
    Scribbles Well-Known Member
    LoUiSiAna
    2010 SR5 PreRunner
    None yet
    I got an email today that trdparts4u was now a dealer for the harrop e-locker
  9. Feb 22, 2017 at 8:24 PM
    Pigpen
    Dan
    Northwest Montana
    @Kyitty
    It gets cold in Bozeman, then sunny and warm, then freeze your tits off cold, then rains, then cold af... You get the point. The man will chime in soon.
  10. Feb 22, 2017 at 8:52 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    hmm, as a person that has had an ARB in trucks since 2000, i have never had an issue. from freezing, to desert. it works well. you also get the bonus of having a air compressor on board for airing up your tires at the end of the day. Have never had one fail or leak. Just install they properly and you should be good to go. route your air hoses cleanly and you wont have any issues.
    Kyitty likes this.
  11. Feb 22, 2017 at 9:06 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I feel the same way about air being "more complicated" than electric, BUT it's still reliable and having OBA is a plus. I might not have done extensive research on it, but I haven't heard of any reliability issues with air lockers in cold weather. :notsure:
  12. Feb 22, 2017 at 9:07 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I can't say definitively that it's not possible but I've had no issue. However, the only time I've used my lockers during winter was on a 30+ degree day. I've never used them on road of course.
    In theory the only thing that should be in those lines is air. Though I suppose condensate could pool and freeze somewhere. But I've had no excuse to use the lockers in sub zero temps yet!
    On road I stick to 4H without lockers and have cruised icy I-90 at 75mph without issue. I'd rather allow slipping on ice to prevent loss of control. That's what the "limited slip" is partly about, allowing traction control.
    Edit: BTW - ARB is from Australia... where did you hear their lockers are US made?
  13. Feb 22, 2017 at 9:14 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Australians know their shit, I like my ARBs but honestly either one you will be happy. I've yet to find major failures of either one.
  14. Feb 23, 2017 at 6:36 AM
    tgear.shead
    Their compressors aren't exactly going to give you 15 CFM to run your air disk grinder. Basically just a tire pump, and having the tire pump bolted in under the hood where it will get sprayed with salt in the winter really isn't an advantage. Just go to Amazon and buy a ciglighter plug tire pump for $15.
  15. Feb 23, 2017 at 6:45 AM
    Justinlhc
    I've already got 4gal at 120psi on tap. No plans on using an air grinder with it though.
  16. Feb 23, 2017 at 6:47 AM
    tgear.shead
    That was general advice to address the theoretical benefits, not a specific recommendation for you.
  17. Feb 23, 2017 at 6:51 AM
    Pigpen
    Dan
    Northwest Montana
    The ARB dual compressor runs air tools just fine - from what I've read. You just need a tank onboard.
    Justinlhc likes this.
  18. Feb 23, 2017 at 6:51 AM
    Justinlhc
    No salt on the roads out here either.
  19. Feb 23, 2017 at 6:52 AM
    Pigpen
    Dan
    Northwest Montana
    Salt doesn't get under my hood. It gets on everything behind the front wheels.
  20. Feb 23, 2017 at 6:06 PM
    04TacoRunner
    04TacoRunner Toyota Junkie!
    CC TX
    I honestly wouldn't worry about the air lines freezing there are ton's of trucks in Iceland that use ARB lockers and they have some really high humidity as well.
