Tjm Pro Locker vs. ARB Locker
Discussion in 'Technical Chat' started by jowybyo, Dec 31, 2016.
  1. Dec 31, 2016 at 5:23 PM
    jowybyo
    jowybyo [OP] Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Looking to get a locker. Ive heard a lot of bad things about the ARB seals going bad on the bearing and pressurizing the diff causing fluid to be pushed out and seals to be blown out.
    The TJM seems to get around this problem and be well built. Anyone have any advice? Seems like the ARB is still the go to locker of choice.
  2. Jan 2, 2017 at 6:37 AM
    Regcab05
    Regcab05 Well-Known Member
    David
    Atlanta
    05 regular cab 4x4
    I scored a deal on a TJM Pro Locker at Summit Racing $661 for the 8.4 rear, sale is still up as of 1/2/16. I've been calling TJM USA from time to time for an update on the 8.0 clamshell front, spoke to them recently, ETA for the front is middle of 2017. I'm getting a little impatient for the front release because I want to take my truck to East Coast Gear Supply for the install. I trust them the most because if it wasn't for their invention of the front diff bearing most of us would not be lifting our trucks. I tried in 2006 and had to put it back to stock until it was invented. They did my 4.88 gears years ago, 700 mile round trip. I've also been checking out the Harrop Elocker available from Yotalockers.com $1300 for the front. I can't find the link or even know how to link it, but search the locker destruction test performed by a 4wd Australian magazine and link it here if you or someone else can find it. It was the best read on lockers I've ever found on the whole internet. The tested ARB, TJM, Harrop, and many more.
    boostedka likes this.
  3. Jan 2, 2017 at 6:41 AM
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
  4. Jan 2, 2017 at 6:42 AM
    jowybyo
    Joe
    Baltimore, MD
    I'll check out the review. Did you go with the TJM because you got it on sale or do you think the design is better?
  5. Jan 2, 2017 at 6:43 AM
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    Both reasons, and the review.
  6. Jan 2, 2017 at 8:49 AM
    jowybyo
    Joe
    Baltimore, MD
    Interesting write up. All the negative things I've heard about the ARB have been long term issues, like the seals on the actuator bearing wearing out. Also I heard ARB is crappy and they make it difficult to get replacement parts. None of these things were "tested" on this write up.
    After reading the test, the Detriot is seeming more interesting.
  7. Jan 2, 2017 at 12:11 PM
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    I like the air actuated design better on the TJM vs. ARB, it's external, but if something goes wrong with the TJM you still have to pull the third member just like the ARB. There's no removable diff cover like Dana axles. Another good thing about the TJM is if you opt to put the air compressor inside the cab there will be no fear of gear oil smell in the interior cabin, which I've heard can be a problem with ARB's. About the Rear Detroit, it adds more slack to the driveline. So with and auto trans shifting from park to drive you might feel the driveshaft thud, and with a manual trans you might feel the extra slack every time you shift. I didn't want the Detroit in the rear, I don't live in a place with much snow or ice (Atlanta) but that may not always be, I would like to transfer to Colorado one day.
  8. Jan 2, 2017 at 12:38 PM
    jowybyo
    Joe
    Baltimore, MD
    I heard similar issues with the ARB. It seems they actuator design isn't as good as the TJM. hmmm. I'm on the fence. Can you swap the seals and o-rings on the ARB actuator without removing the unit from the 3rd?
  9. Jan 2, 2017 at 1:11 PM
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    The ARB has to be removed as well. By the way I have your ribbed tailgate skin and cap. It's the best one on the market.
  10. Jan 2, 2017 at 1:14 PM
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    The cross pins on the TJM are solid piece like a u-joint, I don't think the ARB is a one piece design but still very strong.
  11. Jan 2, 2017 at 2:33 PM
    jowybyo
    Joe
    Baltimore, MD
    Thanks.
  12. Jan 2, 2017 at 2:36 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    There is a thread of an aftermarket electric locker (front & rear). You should consider them too.
  13. Jan 2, 2017 at 2:56 PM
    jowybyo
    Joe
    Baltimore, MD
    Link? Price?
  14. Jan 2, 2017 at 3:01 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
  15. Jan 2, 2017 at 3:02 PM
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    He must be talking about the Harrop/Eaton Elocker available at Yotalocker.com $1300 a piece, no air compressor needed.
    Chipskip likes this.
  16. Jan 15, 2019 at 7:40 PM
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Old thread but does anyone know if TJM is still making the pro locker for the 2nd gen Tacoma. I can’t seem to find out for sure, most links to it are invalid and TJM’s website only lists parts for the Hilux and Prado.
  17. Sep 8, 2019 at 9:44 AM
    brwntms
    brwntms Well-Known Member
  18. Sep 8, 2019 at 3:25 PM
    weldo
    Pittsburgh, pa
    Cool thanks!
  19. Oct 1, 2019 at 10:53 PM
    azgunrunner
    azgunrunner A guy that knows a guy, that knows a guy...
    George
    Arizona
    06 DCLB Sport
    ADS 2.5, Dakar leaf springs KMF sliders CBI Ditch light mounts, DD SS3 pods Bumpers pending OBA pending
    I’ve got one new I the box if you’re interested, send me a note.
