Tko2 mpg drop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by beenjammin, Dec 15, 2015.
  1. Dec 15, 2015 at 1:59 PM
    beenjammin
    beenjammin [OP] Well-Known Member
    Auburn, AL
    2016 TRD 4x4 ORDCSB
    i put on bilstein in front at .85 and 265/75/16 TKO2 and mpg is 18.3 a drop of ~2 mpg. I drive 30 mins to work Almost intirely hwy miles.
    Scottyd and proven21 like this.
  2. Dec 15, 2015 at 2:07 PM
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
    :thumbsup::deadhorse:
    moe2o4 likes this.
  3. Dec 15, 2015 at 2:08 PM
    Large
    Large Red
    So you put a lift and more aggressive tires and lost mpg. Welcome to the club I guess :notsure:
  4. Dec 15, 2015 at 2:09 PM
    3dBdown
    3dBdown Well-Known Member
    2016 DCLB BBP 4x4 Sport
    Are you accounting for the larger tire diameter?
  5. Dec 15, 2015 at 2:13 PM
    adrenalnjunky
    adrenalnjunky Well-Known Member
    West Monroe, Louisiana
    07 PreRunner SR5 DCSB
    billie 5100's front @ .85"
    You went to a tire almost an inch taller, so your odometer isn't quite the same as it was before. Also, depending on what tire was on the truck, you might have picked up 10-12lbs more per tire. Something like a stock Rugged trail is about 38lbs, the bigger ATKO2 is 53lbs according to BFG. Rotating all that extra mass costs fuel.
    0uTkAsT likes this.
  6. Dec 15, 2015 at 2:39 PM
    LowcountryScout
    LowcountryScout Well-Known Member
    SC
    2019 TRDOR 4x4 DCSB SW
    I have no lift and replaced my stock tires with stock size BFG KO2's and had the same results -2. The price I am more than willing to pay for better tires.
    Scottyd likes this.
  7. Dec 15, 2015 at 2:56 PM
    silver60
    silver60 Well-Known Member
    Dallas Tx
    2016 tacoma 2010 rx 350 2009 ctsv 1970 camaro
    I get 18.3 on stock rubber.....only 1000 miles right now and haven't had a good hwy trip to gauge, I did drive 225 miles each way DFW to Austin and barely got 20mpg...there was a hell of a head wind though....it's affected previous vehicles considerably so I won't count that against the taco
  8. Dec 15, 2015 at 3:11 PM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    And ignored...
    thewarriordinghy and Scottyd like this.
  9. Dec 15, 2015 at 5:08 PM
    Scottyd
    Scottyd Former Raptor Owner.
    Scott
    2016 LB TRD Sport
    TOYTEC suspension Nitto Terra grappler Diamond stitch leather
    True story. I upgraded to 265/65/18 Nitto Terra Grappler G2 and Toytec suspension. My results were almost identical to yours. HOWEVER,,, I know have 2,700 miles on my truck and I seem to have picked up .5 mpg
    I'm definitely not a gear head. But it does seem my fuel economy has increased slightly? I did do the TRD drop in filter and would really like to do a exhaust but I don't see to many options and I'm hesitant on this as I believe the current exhaust and ds4 engine work in harmony. I just don't want to hurt my performance. Maybe after some more miles you will pick up a little fuel economy like I did.
  10. Dec 15, 2015 at 5:33 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The heavier tire with with more aggressive tread has more rolling resistance. Most everyone I know that changes from an AT tire to a more aggressive tire loses about 2 mpg on any vehicle. Changing to a slightly taller tire won't make that much difference. You in effect change the gear ratio from 3.73 to about 3.63 with the OP's combo and if all else is equal should see a slight improvement in fuel mileage. It is when you go up to 33-37" tires that you see dramatic changes. I'm running 265/75/16's on my truck but stayed with a pretty conservative tread pattern in a P series tire. (Cooper A/T3's) That is enough tire to get me into and out of some pretty bad places. There were no noticeable changes to performance or fuel mileage.
    As your tires wear they get smaller. A set of 265/75/16's with 35,000-40,000 miles on them will be about the same height as 245/75/16's new. My son is an electrician who works construction. Last year about this time he was commuting exactly 100 miles round trip to a work site. He bought new tires (same size) and the mileage changed to 95 miles round trip with the new tires.
    Scottyd likes this.
  11. Dec 15, 2015 at 7:02 PM
    beenjammin
    Auburn, AL
    2016 TRD 4x4 ORDCSB
    Obviously you didnt smart-ass if you typed this. And.. yep, I knew it would drop some mpg, but for those interested to see just how much adding these popular tires and raising it a tad effects gas milage, it is informative. If you dont think think it was, then why bother taking the time to troll my thread. Nothing good comes out of it except a silly spectacle that mods end up having to jump in on.
    This is what forums are for. If everyone knew everything, there there would be no point. I know you typing on a keyboard of phones makes it easy to forget you are talking to other people.
    I do appreciate those with constructive comments.
    silver60, UrbanT@co and Scottyd like this.
  12. Dec 15, 2015 at 7:47 PM
    silver60
    Dallas Tx
    He's a troll, and a weak one at that
  13. Dec 16, 2015 at 4:07 AM
    SR5W
    SR5W Member
    2016 Tacoma SR 5 speed in white
    Ok I am so new to the Tacoma I do not know what the shock settings mean? Are the Bilstein on my SR or are they an upgrade? BTW thank you for the tire information, I am considering upgrading my stock Toyo's to the KO2's in that same size and had wondered about the effect on the gas milage in my 4cyl!
  14. Dec 16, 2015 at 4:42 AM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    These boys are referring to an upgraded shock - the Bilstein 5100 series which has an adjustable height of sorts. Your stock shocks don't do this.
    Lots of good tire choices out there other than the KO2's which are much lighter. With your 4cyl a heavier tire is what will kill you. Stick to P rated unless you off-road and/or want to sacrifice some MPG's in the interest of puncture resistance. If so get an LT tire rather than P, C rated load. (LT265/75r16C). C load tires (6 ply) have the same stronger reinforced sidewalls as the E rated (10 ply) but are lighter and are more than adequate for a non-towing Tacoma that doesn't wheel on sharp rocks. Maybe I'm telling you things you already know.
  15. Dec 16, 2015 at 5:24 AM
    SR5W
    SR5W Member
    Thanks for the information...I know very little but am having allot of fun with this truck. I had not considered the weight factor of the KO2 so glad you brought that up...
  16. Dec 16, 2015 at 6:01 AM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    I am running 265/75/16 Cooper ATP's right now and I am considering going down to 265/70's in the KO2's just to save some weight. I just love the look of these tires, but I don't want to hurt my mpg's for them. I am considering getting some lighter rims as well. I think you really need to consider what you want out of your truck before adding mods.
  17. Dec 16, 2015 at 6:06 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    I put an LT4 in my YJ turning 48's and dropped about 13mpg. I had no idea that would happen.
    PerfectTekniq likes this.
  18. Dec 16, 2015 at 12:56 PM
    kerrdog
    kerrdog Well-Known Member
    2016 trdor mgm
    im running toyos 265 75 r16 open country mt. my mileage dropped also but those tires are 58lbs. I expected to lose mileage and I have was getting 20mpg now im in the 16s
