TMPS - Help!
Discussion in 'Wheels & Tires' started by Bluesjam, Nov 14, 2020.
  1. Nov 14, 2020 at 2:02 PM
    Bluesjam
    Bluesjam [OP] Well-Known Member
    Paul
    2020 Tacoma SR Magnetic Grey Double Cab 4x4
    A month ago I bought a new 2020 SR with the standard steel wheels. My SR is MGM and I looked at a couple hundred pictures on the forum on MGM trucks with different wheels and overall I liked the SR5 Alloy wheel the best, also money is a big factor. So today I checked Facebook Marketplace and someone 15 minutes from my house has a set of SR5 Alloy wheels with some Toyo tires and no TMPS for $400 that he took off his 2019 SR5. I met him and bought the wheels/tires. Drove to my tire store to change out my tires to the SR5 wheels with my TMPS and then mouth the Toyo tires on my steel wheels so I could sell them. My TMPS will not work on the alloy wheels. My senors are at an angle and they hit the wheel before they can be tighten enough to seal. The shop guys showed me. They said I need a straight sensor. So I come home and look on Rock Auto. I guess I can sell my sensors but could use some help on what to buy that will work. Also I see about relearn, does that work?
  2. Nov 14, 2020 at 3:03 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Have UR tire shop install rubber stems
    screw the TPMS....put a stickie over the dash icon
    Key-Rei and PennSilverTaco like this.
  3. Nov 14, 2020 at 3:14 PM
    Bluesjam
    Paul
    That’s what I did to get the wheels mounted but I want the atMPS to work.
  4. Nov 14, 2020 at 7:04 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Just make sure you pick ones for alloy wheels (read description) and some state no programming and some need programming. Something your tire shop should be able to do.
  5. Nov 18, 2020 at 10:48 AM
    Go Fish
    Go Fish Well-Known Member
    2022 SR5 4x4 DCLB
    The tire shop might refuse to do this. Legally they are not supposed to disable the TPMS since it is a "safety feature".
    Armed in Utah[QUOTED] likes this.
  6. Nov 18, 2020 at 10:57 AM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    42607-06030
    I got those from tpms.com
    Work perfectly
  7. Nov 18, 2020 at 3:16 PM
    Armed in Utah
    2003 Lexus LX 470
    good point
  8. Nov 20, 2020 at 12:45 PM
    Bluesjam
    Paul
    IwillTaco, you are right. TPMS.com is the place to buy from. Best price anywhere. 42607-06030 is the right number and I wish I had never got the ones from the car parts store, they don’t work.
    Iwilltaco likes this.
  9. Nov 20, 2020 at 7:26 PM
    TrekkingTacoma
    TrekkingTacoma Well-Known Member
    Evan
    Knoxville, Tennessee
    2000 SAS Toyota Tacoma
    Your tire shop should carry TPMS sensors. We usually charge $45/tire for sensors. Plus it’s a selling point to keep the old sensors in your old wheels.
    A lot of times a company has a brand they prefer so they can reset it if you ever have the need. Also on your old wheels with the sensors in them, store them 50-75ft away from where you park your truck or your truck will try and sync the old sensors again
  10. Nov 20, 2020 at 7:43 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  11. Nov 20, 2020 at 7:50 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Replace the sensors with some that work. You're talking about $100-$200 every 7-10 years. You'll have to skip 1 or 2 meals each year at McDonalds to cover the cost. They are on Amazon for $20-$25 each and if you'd had them before hand there would have been no charge to get them installed. You're looking at $10-$20 per tire for installation now.
  12. Nov 21, 2020 at 7:07 AM
    Bluesjam
    Paul
    Hopefully the one I have on order from TPMS.com are the right ones. This will be my second go around.
  13. Nov 21, 2020 at 5:51 PM
    daljaz
    daljaz Active Member
    Florida
    prerunner
    custom grille, chrome package on door handles, dual exhaust, custom wheels
    I just today, November 21 had new trd alloys installed on my new 2021 SR. It came with steelies. The tech at the tire shop did the 180 turn and
    the OEM sensors worked just fine. As soon as I started the engine, the light went out. I just need to warn any tech that does later work about the
    position of the sensor in the wheel and have him break the tire bead opposite the sensors. This little trick saved 100's of bucks.
  14. Nov 21, 2020 at 5:57 PM
    Bluesjam
    Paul
    I talked to my guys about doing that and they convinced me that they would get broke next time it was broke down. I should have made them do that. I would have saved a lot of money.
  15. Sep 4, 2021 at 6:12 PM
    troutarebeautiful
    troutarebeautiful Well-Known Member
    2021 Army Green TRD Sport AC/MT
    Just want to say thank you for this comment. This def was the cheapest I've found for OEM quality.
    Iwilltaco[QUOTED] likes this.
