To all the electricians out there....
Discussion in 'Off-Topic Discussion' started by Toywoodsguy82, Feb 2, 2020.
  1. Feb 2, 2020 at 1:26 PM
    Toywoodsguy82
    Toywoodsguy82 [OP] Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    Long story short.... the new place im moving to doesn’t have power in the “garage” (more of a storage unit”. It does have a light in there throw and I was wondering what I could run off of it without popping the circuit with one of those that’s pictured below. Currently all I have that is a powered tool is my chop saw but my tool chest has a power strip and I will need to know how to keep my dewalt batteries charged... B26D2599-2F54-4363-A3B0-4C2AD7120B9D.jpg
    Tacosail likes this.
  2. Feb 2, 2020 at 2:45 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Not an electrician, but likely a 15 amp circuit. Check the breaker box and the breaker for that circuit should indicate the amps for the circuit (15, 20 etc).
    Your max current draw on that light socket needs to be the above number of amps minus how ever many amps are being pulled on the same circuit... e.g. if there is a 100w light bulb in he socket and nothing else then it would be drawing 0.83 amps, giving you 14.17 to work with.
    For charging batteries or listening to the radio should be good. For a chop saw, may be pushing it upon start up or if you really bog the motor down.
  3. Feb 2, 2020 at 3:00 PM
    Toywoodsguy82
    Patrick
    Oregon
    The breaker box for this “garage” is in a different “garage” which is why I was asking
    Clearwater Bill likes this.
  4. Feb 2, 2020 at 3:04 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Plug in a heater and the saw you'll soon find out where the breaker is.
  5. Feb 2, 2020 at 3:04 PM
    Clearwater Bill
    Billy
    Largo Florida
    You need access to any breaker that protects devices in your unit.
    My condo garage is on a breaker with 2 other garages. But the panel is in a common room and the breakers are well marked.
    Thatbassguy and shakerhood like this.
  6. Feb 2, 2020 at 3:05 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    This sounds like a DIY wire job. If you don’t have ready access to the breaker it’s going to be a PITA when it pops. Anyway keep the fire insurance current.
    Thatbassguy and whatstcp like this.
  7. Feb 2, 2020 at 3:05 PM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    Not an electrician but I am a fire investigator. I would not do that.
    Thatbassguy, 916carl and whatstcp like this.
  8. Feb 2, 2020 at 3:09 PM
    tcjacado
    tcjacado Well-Known Member
    Laughing to hard at this :rofl::rofl::rofl:
  9. Feb 2, 2020 at 3:10 PM
    Toywoodsguy82
    Patrick
    Oregon
    I’ll look around. Only been to the new place a hand full of times and didn’t realize until now that I had no power in there. I could run an extension cord from my place but it needs to be rolled up every time because it crosses the driveway
  10. Feb 5, 2020 at 6:52 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    A few things you should understand about what you are considering . That device is a light duty unit, at best. You will be alright with a light bulb and a radio, but I wouldn't leave anything plugged into it when not there. With this device, you have no ground terminal , so no place to plug in the common three prong extension cords. Also , no ground protection , and most likely no ground fault circuit interruption protection . So, with every electrical safety advancement in the last 70 years thrown out the window, what could go wrong ? Don't want to scare you, just want to make you think safety.
    You will be alright charging phones and even a tool battery or two. If you can find a power strip with a built in 10 anp breaker in it, it will keep you from overloading the 15 amp lighting circuit. It will trip before it trips the breaker in a remote location.
    Is the light on a switch ? Could other garages use the same lighting circuit ?
    Thatbassguy likes this.
  11. Feb 5, 2020 at 7:08 PM
    Fire Arrow
    Fire Arrow Hanging out at work
    Jim
    MD
    2016 Black DCSB SR sold, 21 Tundra Limited MGM
    Very likely that one lighting circuit serves multiple units.
  12. Feb 5, 2020 at 7:15 PM
    Toywoodsguy82
    Patrick
    Oregon
    It’s a rental or else I would ask for an outlet.
    whatstcp[QUOTED] likes this.
  13. Feb 5, 2020 at 7:23 PM
    Fire Arrow
    Jim
    MD
    The electrical code does not allow a regular receptacle on greater than a 20 amp circuit.
  14. Feb 6, 2020 at 5:26 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Legally you can't use a standard 20 amp outlet on a 30 amp circuit. It is legal to wire multiple garage outlets on a single circuit so you basically have no ideal of the power demand because of the multiple load use. The instant you touch any wiring in a setup like that you become responsible for all of the units and it's kind of doubtful your insurance co. would touch it. Because of the length of the runs it probably a #12 wire protected by a 20 amp breaker so one little electric heater in the mix you are in the 9-10 amp range on a 20 amp circuit.
