To all the guys looking at overpriced rusted trucks
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cucvfan, Nov 29, 2022.
  1. Nov 30, 2022 at 11:09 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Also might add....got rid of the oem caliphers....
    and switched to Napa premium eclipses.....
    epoxy coated so the seals dont fail......
  2. Nov 30, 2022 at 11:13 AM
    O'Silver_Taco
    MD
    For all in northern states.....the por 15 system is way to go
    etch, rust coat, top coat.....
    Amazon.com: POR-15 Rust Preventive Paint - Gloss Black - 1 qt - Rust Preventive Paint | Stop Rust & Corrosion Permanently | Anti-Rust Protective Barrier : Automotive
    https://www.amazon.com/POR-15-40204...9bc-4fa0-91cd-d80dc3d7fa08&pd_rd_i=B00J5940JE
    But for best results.....needs to be done during summer time.....
    Mines a texas truck....tiny bits rust here and there....I still went on the hunt....
    thats how I know about the after market part rust trap......
    Little tip here....if your not changing brake fluid every 4 or 5 yrs.....lines are rusting from inside out....
    They're trying to keep pace with your power steering hoses....
    that is the hidden decay.....from the inside......
    crap turns into liquid sand paper...
    nothin lasts forever......
    7 yr coolant....my ass....
  3. Nov 30, 2022 at 11:28 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I’ve got 2 at around 200k, one with almost 500k, one just under 100k and one at 300k. Damn good trucks. Just rust is the issue.
  4. Nov 30, 2022 at 11:36 AM
    O'Silver_Taco
    MD
    Back in day we used this green.....zinc chromate from the paint stores...
    made for ship yards and stadium I-beams......
    But the EPA showed up one day.......
    the newer stuff is a shadow of its former........
    Over protect your differenial.....those are getting expensive and/or impossible to get....
  5. Nov 30, 2022 at 12:01 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Watch out with that zinc chromate stuff, if you ever have to weld on the frame your going to be very exposed to hexchrome which is not something you want to mess with. Even the high zinc primers aren't great, I gave myself zinc poisoning welding on my frame after I didn't grind the paint totally off, and didn't turn my fan off because I was only going to run a few beads.
    If you ever curious what the inside of your rusty truck frame rails look like:.
    0xDEADBEEF and Cucvfan[OP] like this.
