To anyone that has removed a cap, is this crazy?
Discussion in 'Tonneau Covers, Caps and Shells' started by Eagle200, Jul 4, 2023.
  1. Jul 6, 2023 at 6:45 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Build a pergola style carport if you can't use the garage for overhead hoisting. Either you need a hoist system or you need to rethink your topper.
    For storage, I would put it on a customized wheeled cart, solid plywood base with 2x4 supports underneath. Wheeled because you want to store it out of sight where it's not an eyesore or temptation. Solid base because things that are stored low to the ground as you want are a neon-lit invitation to rodents and insects.
  2. Jul 6, 2023 at 7:47 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Absolutely not. You'd be trusting the bolts (that are less than 1/4" I believe) that hold the roof rails on the cap, and risk ripping them straight through the fiberglass with that amount of weight. The cap needs to be supported from the bottom.
    Jeffch[QUOTED] likes this.
  3. Jul 6, 2023 at 7:51 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    How do people lift in garage run straps between bed rail and cap?
    I was thinking 4 rings on roof rail?
    Good thing I don’t need it removed yet.
  4. Jul 6, 2023 at 8:05 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Ideally you'd slide a pair of 2x4's underneath. I know people do straps or hooks, but that would make me nervous personally - those are going to introduce lateral stresses to the fiberglass, and long term, it might be worrying over a nothingburger, or it might be just enough to deform or crack around the rear hatch.
  5. Jul 6, 2023 at 8:20 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    1st rig I’ve had with the fiberglass cap I’ll just leave it on I like it on anyway!
  6. Jul 6, 2023 at 2:45 PM
    Go Fish
    Go Fish Well-Known Member
    2022 SR5 4x4 DCLB
    Maybe something like this could be made to work: https://www.etrailer.com/Camper-Jacks/Brophy/CJ31.html?feed=npn | Shop - Camper Jacks&adgroupid=91321603372&campaignid=293732897&creative=404001548819&device=c&devicemodel=&feeditemid=&keyword=&loc_interest_ms=&loc_physical_ms=9033169&matchtype=&network=g&placement=&position=&gclid=EAIaIQobChMIgLW89tf4_wIVEfDICh2nSQVNEAQYASABEgIPG_D_BwE
    Since canopies usually have very little overhang, you would need to figure out a way to support it on the shelves of the jacks. Maybe 2x4s across under the canopy with the ends resting on the jacks.
  7. Jul 6, 2023 at 9:01 PM
    Eagle200
    Eagle200 [OP] Well-Known Member
    2021 DCLB Off-Road
    would be a couple times a year. trying to reduce weight for towing a camper i hope to buy. thanks for advice
  8. Jul 6, 2023 at 9:02 PM
    Eagle200
    2021 DCLB Off-Road
    think i would need 2 or 4 to keep it stable?
  9. Jul 6, 2023 at 9:19 PM
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    Last time I had wife help with something, she pinched a finger so bad it broke it & damaged the nail bed. That was 5 years ago & the nail fell off & never grew back. Find a guy/neighbor to help.
  10. Jul 7, 2023 at 6:18 AM
    Off Topic Guy
    Sounds like you might have bigger problems than an additional 150 lbs in tow then. Maybe aftermarket leaf springs/airbags should be in your near future. But, to keep to your original topic, if you're needing a solution for 2-3 times a year, thats probably not worth the investment for some wild hoist/lift system. Get some 2x4's, eye bolts, and ratchet straps and call it a day. Or some 2x4's, sawhorses, and a neighbor.
  11. Jul 7, 2023 at 2:08 PM
    Eagle200
    2021 DCLB Off-Road
    airbags for the truck?
  12. Jul 7, 2023 at 2:57 PM
    Go Fish
    2022 SR5 4x4 DCLB
    One on each side is enough, just make sure it's balanced. When I was a kid we used these on a full sized 9ft. camper. They were stable enough to lift the camper and set it on the ground or put it back on the truck.
